Ashtray light
Originally posted by NSXNEXT
You have to buy the smokers package. That kit has a light.
Smitty
Originally posted by lou
all you have to do is ground the solid red wire that goes to the light...the red with black stripe is 12 Volt.
Smitty
Originally posted by Smitty
... thanks Lou... I knew I missed this awhile back so I went hunting with the search funtion.. I came across your post about it but the post just died without a resolution..
Smitty
Smitty
nighthawk the wires are already there disassemble the bottom portion of the dash and take off the piece around the shifter....then you will see the 2 wires on top that go to the light that lights up the ashtray....the 12 volt is already there all you have to do is ground the solid red wire and the ashtray will light up when you put you headlights on
this is without the green condom on the little light bulb.
Originally posted by Nashua_Night_Hawk
Which part should be disassembled?
Lou
The CL Crazy
I looked under there before i go hunting for the wire. It doesn't look like there's a light there. On the top there is just some grooves that are indented, is the light in there?
mada51589
05-03-2022 08:54 PM
sockr1
10-01-2015 01:31 AM
wusty23jd
09-24-2015 11:41 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
