Aquamist H2O Injection installed...
Old Jul 8, 2005 | 04:43 PM
allmotor_2000's Avatar
I did the install this morning - took about 3 hours including some basic tuning. The damn hose to the tank was not long enough so it is currently residing in my back seat (with the seat-belt!)!!
It's not too tough to install... some plumbing and some wiring
It's really hot today but car felt good. Not sure if its quicker but I guess I won't know the impact of this until I try to increase boost.
Old Jul 8, 2005 | 05:06 PM
m&b6speed's Avatar
buy my car
your mods kick ass. when are you going to increase boost??
are you going to take the newest setup to the track
Old Jul 8, 2005 | 05:31 PM
Smitty's Avatar
where is the DYNO!!!!...
Old Jul 8, 2005 | 06:50 PM
NiteQwill's Avatar
Adventurist.
pictures puhhhleaaseee....
Acura2.3CL's Avatar
def post some pics after you get it completely installed (not in backseat)...great job by the way!
Old Jul 8, 2005 | 07:02 PM
It's hot today... I am not going to the garage again!
Old Jul 8, 2005 | 07:07 PM
I hope to try 7-8psi... and unless my engine has gotten weaker it should hit
450+whp if I am successful.
Old Jul 8, 2005 | 07:13 PM
On yeah... btw I have 0-degrees timing retard now and no knock that I can hear. Used to have -4 degrees.
Old Jul 8, 2005 | 10:17 PM
mrsteve's Avatar
Can do you check the IAT drop while injecting? What psi do you start injecting?
Old Jul 9, 2005 | 12:12 AM
Like 4psi.... its not like a S/C... so pretty much whenever I get to 4psi... I am on the way to 6psi.
I have not done any IAT measurements... tomorrow!
Old Jul 9, 2005 | 02:40 PM
Well... I'm a dodo!! No wonder the car never felt quicker! There was a leak as I had not put the hose in tight and when I was tuning (had the jet on the windshield) the water seemed to not be that 'atomized'.... so I tightened it and voila... its like steam now!
So... install it back in the intake tract and the results are more dramatic. AFR is running about 0.5 higher. Around 12.0:1. This is okay as you can run 12.7:1 while injecting water. This tells me that the intake charge is denser and hence more air gets in. It's like 90+ today but I only really noticed a 5F drop in IAT but then again I wasn't continuously flooring it to really take a good measurement.
The biggest improvement is the delivery of power - its MUCH smoother... I mean significantly smoother throughout the RPM range. I suppose it gets rid of the slightest detonation (the amount we cannot feel/hear) and any/all misfires. I will try higher boost one of these days as well.
Funny thing... I had the bumper off and was driving around trying to tune the car and this Neon SRT-4 starts messing around and *psffftt* 'ing me! I think I wallopped the guy by 20 car lengths!
Anyways, its a good investment - makes my setup safer and potentially allow me to increase boost...
Old Jul 9, 2005 | 03:02 PM
Allout's Avatar
Blown is Best
Sounds very promising Ram Are you spraying pure water or water/ethanol?
Old Jul 9, 2005 | 03:07 PM
Allout's Avatar
Blown is Best
Based on what you're seeing, would this kit allow me to run the HBP on 91 octane safely in the 100 degree environment here in Fresno?
Old Jul 9, 2005 | 03:16 PM
I am running 100% water right now but will switch to methanol/water combo soon. And yes... I believe you can run the HBP with 91-octane if you have this mod.
Old Jul 9, 2005 | 03:24 PM
Allout's Avatar
Blown is Best
Thanks Looks like I'm going to start shopping for a kit
Old Jul 9, 2005 | 03:52 PM
m&b6speed's Avatar
buy my car
once again way to raise the bar and squeeze out more performance
Old Jul 9, 2005 | 07:20 PM
Smitty's Avatar
good old ADI
Anti detonation Injection
Old Jul 9, 2005 | 09:34 PM
mrsteve's Avatar
I'll be doing this mod some time next month. Probably in 6 weeks or so. The IAT on our setups is much higher than Ram's car so we have more potential to lower IAT.
Old Jul 9, 2005 | 10:06 PM
If you are non-intercooled... then yes, you have more to gain!
So just drove back from playing Poker with a couple of guys (3 in the car including me) and was flooring it a bit... usually I detonate with 3 people in the car. Now... NOTHING... absolutely NOTHING!
Old Jul 10, 2005 | 09:51 AM
Smitty's Avatar
I think I can install the ADI on the front plate of the Intercooler... it will dump right into the runners after the charge is already cooled via intercooler..... added safety..
Old Jul 10, 2005 | 11:37 AM
BTW, I have a pic if someone wants to host it...
Old Jul 10, 2005 | 12:14 PM
Smitty's Avatar
smitty@acurazine.com
Old Jul 10, 2005 | 01:49 PM
Originally Posted by Smitty
Check your mail...
Old Jul 10, 2005 | 02:07 PM
Some info on water injection.
http://member.newsguy.com/~gtfour/skeptics.html
One thing I am confident about Aquamist and not-so confident about the other companies is the pump. The pump is the most critical part of this whole setup and if the water is not atomized properly it will not help! In fact larger droplets would have a negative effect!
Old Jul 10, 2005 | 02:38 PM
mrsteve's Avatar
What psi is the Aquamist pump?
Old Jul 10, 2005 | 04:39 PM
dshearon's Avatar
i found this while browsing some hacking sites.... figured you guys might find it interesting....
http://www.dawesdevices.com/howto.html
Old Jul 10, 2005 | 05:04 PM
Smitty's Avatar
Old Jul 10, 2005 | 05:38 PM
Peak pressure is 250psi. It can also deliver 300cc/min at 6 bar (6 x 14.7)
Old Jul 10, 2005 | 05:42 PM
power3dfx's Avatar
Parting out 02 Type S :(
Just saw the kit installed. Looks clean and simple, except for the tank sitting in the back seat of his car! lol All in all, this mod should be easy to install but the power is still to be proven. Allmotor, get some methanol mixed in there, and pop in the 7.25 psi spring!
Old Jul 10, 2005 | 07:47 PM
mrsteve's Avatar
Hmmm the kit i was looking at is only 100psi.
Old Jul 10, 2005 | 07:50 PM
mrsteve's Avatar
Also, can you hear the pump while it is on?
Old Jul 10, 2005 | 08:01 PM
If the bumper cover is off and the engine is off... you can. If the engine is on and you are right next to the front fender... maybe. Inside the car or under all other circumstances.. no.
If you put some rubber spacers on the mounting point, you won't hear anything.
Old Jul 10, 2005 | 08:41 PM
m&b6speed's Avatar
buy my car
i only see one pic
Old Jul 10, 2005 | 08:56 PM
mclarenf3387's Avatar
i only see one pic
He means in person
Old Jul 10, 2005 | 09:24 PM
Chemmech's Avatar
Congrates
Old Jul 10, 2005 | 09:27 PM
Chemmech's Avatar
Is that post cooler for the mist nozzle?
Old Jul 10, 2005 | 09:55 PM
^^ not sure what you mean?
Old Jul 10, 2005 | 09:58 PM
m&b6speed's Avatar
buy my car
Originally Posted by mclarenf3387
He means in person
ohhhhhhhhhhhhhhhhhhh
Old Jul 10, 2005 | 10:42 PM
mrsteve's Avatar
I think he means did you install the nozzle post-intercooler. The answer would be yes!
Installing pre-intercooler would reduce the efficiency of the IC.
Old Jul 10, 2005 | 10:54 PM
darrinb's Avatar
///M POWER
i'm a little lost, what does this mod do exactly??
