APEXi AFC NEO ? good for tunes
wazup recently purchased some p2r fuel rail, rdx injectors an the intak emanifold should be getting port an polish this week coming up...but i want the car to get tune but dont know excactly what system i should used...i seen a video on youtube an the kid had his cl s tune with APEXi AFC NEO.... lmk need some suggestions
Whats up with RDX owners?
No.
And RDX injectors are overkill for that.
Stock injectors can handle a port and polish just fine. The stock ECU can for that matter as well.
Bigger injectors will not make more power on that setup. Youre simply wasting gas, and bogging down the motor in the process.
Wouldn't you want a V-afc so you can tune VTEC. I had V-afc in every honda I've owned until the 08 Accord and the TL. I wondered if the V-afc would do the TL some good. I had it on my 03 CL-S6 and it made nice gains after leaning it and lowering vtec to 4k rpm. If you're not running intake/hdr/exhaust the V-afc wouldn't be a good choice until you did have these items
Ultra Negro
As far as I know I thought V-afc was not compatible with i-vtec, i could be wrong I know they work great for the older honda motors and what not, but have yet to see one actually working with the j series, seen a couple on k series but alot of guys go the hondata route.
yeah i got xs headers,comptech cold intake, p2r gasket n throthle body spacer,lightweight crank pulley, hyper medalion exhaust, ngk laser iridium etc..so its good if i used the v-afc
good luck. no current Apexi ANYTHING (neo, SAFC, VAFC) or even AEM F/IC work with the J series engines. You can say all you want. I've done the research, I've talked to the shops all over the country. The tune will run for about 10 minutes and then the ECU will take over and go back to controlling your ignition & fuel system. THE END.
The F/IC has been up and running on the J series for over a year now...
rockyboy
12-06-2022 02:29 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
