Anyone Use Fuel Injector Cleaner?
I usually put a bottle in the Accord at each oil change. But with the new car, it seems pointless since everything is new and clean. Does anyone use a fuel product anyway to keep things clean? By the way, I run either 76 or Chevron... are these fuels good enough for clean running for a while? Thanks.
If your using chevron it has techron which is good stuff for keeping your injectors clean. I don't know about 76 gas... I wouldn't bother with the injector cleaner until you get at least 10,000 miles on the engine or at least 2 oil changes.
I bought a bottle of fuel injector cleaner recently, about 24K miles, and it does make a difference....car was driving smoother. I usually stay with Chevron, and sometimes 76, never Arco.
Using them every oil change i guess will prevent buildup and constantly keep them clean.
I bought a penzoil brand fuel injector cleaner because it was in a Metal container instead of a plastic container.
Re: Anyone Use Fuel Injector Cleaner?
http://www.popularhotrodding.com/tec...PHR_Injection/
Quote: Adding a bottle of fuel injector cleaner to a tank a gas periodically is great preventive maintenance, but often does little to clean deposits that have already set in.
Was that Penzoil injector cleaner called SHOGAN? The can was so cool I had to buy it. The marketing was great. The can just looked fast.
I've used Techron in my cars once a year for quite a while. While I didn't notice any change to my Tbird (it was relatively new when I started using techron), I did notice an improvement on idle smoothness on my 100,000 mile vw bus.
I use techron every year as a preventive maintanence measure, and plan on using it in my CLS too.
This is the stuff the ACURA dealer uses BG44K & is put in at 15K, 30K ect. services I also buy it from them to use between services. www.bgprod.com/autofuel.html
I use the 44K & thats good for every 7,500 miles & the MI 3000 Plus is put in every 3,000 or 4,000 miles I got a can of that free from the ACURA parts guy when I got my brake pads changed & purchased the 44K that he gave me a discount on. I just put in the can MI 3000 PLUS a few hundred miles ago.
$5 every oil change is worth the shot. I've used STP in a large silver container for the last 7 years. Worked super on my old maxima's. Put it in from the start. Using Sunoco 94 & STP in the 2002 CLS...runs like a raped ape so far.
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
joflewbyu2
Oct 8, 2015 11:16 AM
