anyone know how to program a stock alarm remote
Old Nov 8, 2003 | 12:01 AM
916CL's Avatar
Hi wanted to know if anyone knows how to program a stock alarm remote. I bought two remotes on ebay and i brought my car to the dealer and they told me that it would be $90 to re-program it. I think that is crazy, so if any body know how please let me know
Old Nov 8, 2003 | 09:31 AM
Chopsie's Avatar
Beware of leakage
Do a search, they are around here somewhere, Shawn S posted up for me when I was having trouble with mine.
Old Nov 8, 2003 | 10:57 AM
dallison's Avatar
registered pw
you didn't buy the one for like 7.50 did ya?????
if u outbid me!!!!
Old Nov 8, 2003 | 11:04 AM
dallison's Avatar
registered pw
http://cgi2.ebay.com/ebaymotors/aw-c...&userid=legi0n
this guy buys mad keyfobs for all kinds o cars
Old Nov 8, 2003 | 11:05 AM
dallison's Avatar
registered pw
some people collect baseball cards some car remotes
Old Nov 8, 2003 | 11:45 AM
Cruz_msl's Avatar
My Member is Registered
HERE IT IS
1. Turn the ignition switch on (II on the ignition)
2. W/in 1-4sec, push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit. (Just at the steering wheel is fine)
3. W/in 1-4sec, turn the ignition switch off
4. W/in 1-4sec, turn the ignition switch on(II)
5. W/in 1-4, push the transmitter lock or unlock button w/ the transmitter aimed at the receiver again.
6. W/in 1-4sec, turn the ign. switch off
7. W/in 4sec, turn the ignition switch On(II)
8. w/in 1-4sec, push the transmitter lock or unlock again.
9. w/in 4 sec, turn the ign off
10. w/in 4 sec, turn the ign ON
11. W/in 1-4, push the transmitter again
12. Confirm you can hear the sound of the door actuators. W/in 1-4sec, push the trans lock or unlock button again.
13. W/in 10sec, aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch off, and pull out the key.
15. Confirm proper operation with the new codes
Old Nov 9, 2003 | 01:06 AM
916CL's Avatar
thanks I will try it
Old Nov 9, 2003 | 01:08 AM
916CL's Avatar
another ? , if it is really that easy cant a mechanic or somebody that comes in contact with your for a few hours do this on a blank remote and later steal your car or your asscessories. seems to easy
Old Jul 11, 2006 | 02:12 AM
jproy's Avatar
MP90 uninstalled
i bought one on ebay that was for a RL and just swapped the electronics from the old remote to the new remote casing. no need to screw with reprograming just swap the old scratched casings circuit board into the new remote casing. Clean all parts before reassembling. I am about to do the this again as I wear those suckers out pretty quick. I try to take care of it but after a year or so they look like shit.
Old Jul 11, 2006 | 01:58 PM
SleekCLS's Avatar
do they have to look EXACTLY THE SAME? cuz there are some that look different and says its for a CL.
Old Jul 11, 2006 | 02:07 PM
gr4mm4t0n's Avatar
my key fob doesn't have a sticker with the FCC #.
is the FCC # any place else on the car?
... i might just get a new one and change out the guts like jproy.
Old Jul 11, 2006 | 09:32 PM
Allout's Avatar
Blown is Best
Do you have the second remote. Both FCC numbers will be the same.
jproy's solution is also a good one.
Old Jul 11, 2006 | 09:37 PM
jproy's Avatar
MP90 uninstalled
any remote that looks exactly the same as the one you have and has the trunk release button as well as the red panic and unlock lock buttons will work for the key fob guts swap. like i said the case I got was for an RL older RL
Old Mar 7, 2008 | 11:18 PM
qwpobird's Avatar
when do you release the transmitter after pushing??
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
Specmiata82
Sep 30, 2015 10:04 AM
