Anyone ever run 104 octane race gas? If so question
I put 3 gallons in mixed with my 93. Every since I did that, still on the tank which is almost empty, the car is idling a little rough. Any ideas why? I hope it goes away after 93 is back in solid....
Thanks.
Thanks.
SHIFT_over.so.I.can.see
anything over 100 contains lead? I've never heard of this before... can someone tell me more? maybe a link? I thought unleaded means unleaded
running over 93 is a waste of money UNLESS you're putting a lot of nitrous or boosting a lot of pressure in there...
This might be insightful. Higher octane will not do anything for you unless you also find a way to get the engine to do a higher compression.
http://www.howstuffworks.com/question90.htm
Happy CL-S Pilot
There is unleaded gas up to 103... I used a galon of this stuff at the track and I just waste my $5.5!
Check the Unlead Gas here NED racing fuel supplier : http://www.vpracingfuels.com/index2....D8025E5F4AB211
Originally posted by DRM600
doesn't 104 contain lead? doesn't lead clog the cats or foul the o2 sensor or somethign?
There is 117 octane that is unleaded, so no, not everything over 100 is leaded.
Man 117 smells so good compared to regular burnt gas smell. Like on a car without a cat you get the pure smell. It even smells fast.
Anyways guys, I drove this morning and car drove normal. I think the AC makes the idle a little rough. I didn't use the AC this morning.
High Octane unleaded vs. leaded
The 104 octane 'unleaded' gas should cause no harm.... the motor's knock-sensor will in fact advance the timing (or I should really say, retard significantly less) and you will notice a power increase. 'Leaded' gas has a slightly detrimental effect on the catalytic convertor and the fuel-injectors (leaves deposits).
wusty23jd
09-24-2015 11:41 AM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
