anybody tighten their throttle cable?
has anyone tried to remove the slack off the throttle cable? i think i might try this. im getting tired of the soft mush feeling before i get a response when i press the gas pedal. i kinda like the touch and go feeling...
sidemarker
sidemarker
Originally posted by frryy
i think that the slack is there for Safety reasons....you don't wanna rear end someone in traffic just cause you forgot about the lack of slack in the cable.....
sidemarker
Registered Member
I was backing out my sister's new V4 solara, (don't start flaming on the car, it's my sisters car), and the pedal is really sensitive, more sensitive then my TL-S.
I don't see anything with adj. the throttle cable...i would do it if i wanted a quicker response...but i drive mostly on sidestreet so i don't really need to
how would this be done on the 6spd?
Also is it possible to tighten the clutch...mine just doesnt seem to be as grabby as it used to be when I first got it (I might just be used to it now tho)
Who Needs a Type-S?
my AV6 cable was tightened a while ago, i think i have to redo it now cuz the slack seems to have reappeared...unless you're some 300lb monster who cant control his own feet, I don't think you'll be rear-ending anyone...
Originally posted by JasonT
How does one "tighten" the cable on the auto?
1. Look for the Throttle Body of the engine. There are 2 lines/cables going into the engine. Loosen the engine cover to reveal the cables.
2. There are 2 nuts holding each cable. One nut on either side of the cable.
3. Loosen one side and tighten the other to take up the slack of the cables. Don't overdo it, or else you'll have a high reving engine at idle
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Verdict: Slightly better response at partial throttle. I believe the full benefit may be achieved at WOT. The theory here is that with a loose throttle cable, the TB butterfly valves can't open completely during WOT (ie: horizontal), thus impeding maximum air flow to the engine.
Cost Drivers!!!!
Originally posted by xenon7
Did you setup your 6sp already?
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Not yet
Besides, I think it's hydraulic. There's no cable to tighten.
Originally posted by Zapata
Not yet
I want to do it at a meet so the car is blessed properly. I don't feel i have the correct amount of mojo.
Not yet
Ok I must have just gotten used to the clutch....thats good.
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
