Another stupid question...
Old Aug 21, 2001 | 08:55 PM
CL-S-Bo's Avatar
What is DOHC and what is SOHC?
satellite 23's Avatar
d is fast S is slow.
Old Aug 21, 2001 | 08:56 PM
Water Rabbit's Avatar
Wow only on my 2nd tranny
Double Overhead Cam
Single Overhead Cam
Old Aug 21, 2001 | 08:58 PM
RAdams's Avatar
DOHC = Dual OverHead Cam. For each head, there are two camshafts. One acts on the intake valves, the other on the exhaust valves.
SOHC = Single OverHead Cam. For each head, there is one camshaft. It has both intake and exhaust lobes on it and therefore acts upon both sets of valves.
Old Aug 21, 2001 | 09:00 PM
CL-S-Bo's Avatar
Thanks, you guys are dolls. The CL-S is SOHC- right? So, is that bad, rather is DOHC better than SOHC?
Old Aug 21, 2001 | 09:25 PM
mdaniel's Avatar
Yes, the TL/CL/-S are are SOHC. DOHC is more expensive and heavier, but usually allows the engine to rev higher.
Old Aug 21, 2001 | 09:31 PM
Fabvsix's Avatar
Cajun Gumbo Man
AND BURN WAY TOO MUCH GAS !
Old Aug 21, 2001 | 09:43 PM
jdtypeS's Avatar
Lucky Kid Member
Well shit, for the 32k i paid...it should have come with DOHC..i think thats expensive enough for an acura.
Old Aug 21, 2001 | 10:24 PM
jdl75's Avatar
Originally posted by jdtypeS:
<STRONG>Well shit, for the 32k i paid...it should have come with DOHC..i think thats expensive enough for an acura. </STRONG>
A DOHC would not make much difference in our engines. A SOHC simplifies mechanics, and makes everything a little more compact. The DOHC is more likely to be found on a 4-cyl engine, as there is only one bank of cylinders. On a V-6, 4 cam shafts would be a lot of stuff in the engine.
Old Aug 21, 2001 | 10:30 PM
Type S's Avatar
Powered By HONDA
for honda..dohc vtec engine is for high performance engines..but sohc vtec is fuel efficiency...
Old Aug 23, 2001 | 07:29 AM
phatpat's Avatar
SOHC: 3.2L 260hp type-s
DOHC: 3.2L 290hp nsx (3.0L 260hp nsx auto)
DOHC type-s would be nice...
Old Aug 23, 2001 | 09:54 AM
daverman's Avatar
What's the advantage of DOHC exactly? The Acura V6's already have two camshafts--one for each bank of cylinders.
Traditionally DOHC has allowed engines to a. have more valves and b. rev higher. Since the current Acura V6's do fine with 4 valves per cylinder and a 6900 RPM redline, I don't know what DOHC will add to the mix, besides more weight and another part to break.
Old Aug 23, 2001 | 10:11 AM
Bluto's Avatar
Find beauty in dissonance
Someone once posted a SOHC provdes more lo-end power ... a DOHC is more top-end. I would guess VTEC helps our SOHC at the top-end?
Old Aug 23, 2001 | 02:30 PM
Infamuz's Avatar
Retired Post Whore
I wished our cars still had DOHC. My 92 Maxima SE had a DOHC and all the current generation Nissans have DOHC.
knight rider
Mar 4, 2016 08:59 AM
MikeJM310
Sep 24, 2015 07:24 PM
kocyk123
Sep 22, 2015 11:12 PM
