Another question on Sways
Ambidextrous Masturbator
Originally posted by GRF:
<STRONG>Allot of you CLS owners have installed sways, my question is did all of you install front, rear or both? Thanks.</STRONG>
Cajun Gumbo Man
Do we look like HALF ASS MEMBERS ? Of course we do front and back ! These are NOT Ford Pinto's you know !
Hey Fabvsix
Was not trying to insinuate anything. Reason I asked, when I went to a couple of websites selling suspension parts it shows front and back separately.
If you’re talking about the Comptech sway bars -- yes both front and rear went on.
The replacement bar is about 13-20% stiffer in the front.
The rear bar is about 80% stiffer in the rear.
So, if you leave the front Comptech bar off, you will increase the oversteer and the roll will not be reduced in the front...
I am going to put my stock front sway back in this weekend. I would like to be able to induce some oversteer, and will see if this helps. I am sort of experimenting at this point. My current set up is Ground Control coilovers/Koni's with 450/400 spring rates front and rear. These rates are significantly higher than my previous comptech springs. With these springs rates, I am hoping that going back to the stock front bar will help, otherwise I'll run the Comptech bar in front and start looking for a larger/stiffer rear bar.
Kevin
Kevin
Originally posted by Kevin M:
<STRONG>I am going to put my stock front sway back in this weekend. I would like to be able to induce some oversteer, and will see if this helps. I am sort of experimenting at this point. My current set up is Ground Control coilovers/Koni's with 450/400 spring rates front and rear. These rates are significantly higher than my previous comptech springs. With these springs rates, I am hoping that going back to the stock front bar will help, otherwise I'll run the Comptech bar in front and start looking for a larger/stiffer rear bar.
Kevin</STRONG>
Kevin</STRONG>
You should get a 13 to 20% reduction is front roll stiffness -- I really did check the equations out. The stock bar has a 0.107 wall thickness and the Comptech bar has a wall thickness of 0.177. (At least that is what I remember from off the top of my head...)
BTW -- if you want to verify this info -- don't talk to Comptech sales, talk to the technical folks!
navtool.com
31
11-16-2015 08:30 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
