Another question on Sways
Old Aug 1, 2001 | 02:53 PM
GRF's Avatar
GRF
Allot of you CLS owners have installed sways, my question is did all of you install front, rear or both? Thanks.
Old Aug 1, 2001 | 03:58 PM
SidVicious's Avatar
Ambidextrous Masturbator
Originally posted by GRF:
<STRONG>Allot of you CLS owners have installed sways, my question is did all of you install front, rear or both? Thanks.</STRONG>
Most (if not all) people installed both front and rear Comptech Sway Bars.
Old Aug 1, 2001 | 06:55 PM
Fabvsix's Avatar
Cajun Gumbo Man
Do we look like HALF ASS MEMBERS ? Of course we do front and back ! These are NOT Ford Pinto's you know !
Old Aug 1, 2001 | 07:04 PM
GRF's Avatar
GRF
Hey Fabvsix
Was not trying to insinuate anything. Reason I asked, when I went to a couple of websites selling suspension parts it shows front and back separately.
Old Aug 1, 2001 | 07:05 PM
EricL's Avatar
If you’re talking about the Comptech sway bars -- yes both front and rear went on.
The replacement bar is about 13-20% stiffer in the front.
The rear bar is about 80% stiffer in the rear.
So, if you leave the front Comptech bar off, you will increase the oversteer and the roll will not be reduced in the front...
Old Aug 1, 2001 | 07:26 PM
Kevin M's Avatar
I am going to put my stock front sway back in this weekend. I would like to be able to induce some oversteer, and will see if this helps. I am sort of experimenting at this point. My current set up is Ground Control coilovers/Koni's with 450/400 spring rates front and rear. These rates are significantly higher than my previous comptech springs. With these springs rates, I am hoping that going back to the stock front bar will help, otherwise I'll run the Comptech bar in front and start looking for a larger/stiffer rear bar.
Kevin
Old Aug 1, 2001 | 07:29 PM
H@mmerm@n's Avatar
My other car is a 350Z
Kevin, to clarify: you are optimizing your CL-S performance for the track, are you not?
Old Aug 1, 2001 | 07:33 PM
EricL's Avatar
Originally posted by Kevin M:
<STRONG>I am going to put my stock front sway back in this weekend. I would like to be able to induce some oversteer, and will see if this helps. I am sort of experimenting at this point. My current set up is Ground Control coilovers/Koni's with 450/400 spring rates front and rear. These rates are significantly higher than my previous comptech springs. With these springs rates, I am hoping that going back to the stock front bar will help, otherwise I'll run the Comptech bar in front and start looking for a larger/stiffer rear bar.
Kevin</STRONG>
You should get a 13 to 20% reduction is front roll stiffness -- I really did check the equations out. The stock bar has a 0.107 wall thickness and the Comptech bar has a wall thickness of 0.177. (At least that is what I remember from off the top of my head...)
BTW -- if you want to verify this info -- don't talk to Comptech sales, talk to the technical folks!
Old Aug 1, 2001 | 11:21 PM
Kevin M's Avatar
Originally posted by H4mm3rm4n:
<STRONG>Kevin, to clarify: you are optimizing your CL-S performance for the track, are you not?</STRONG>
Yes, I am.
Kevin
Old Aug 1, 2001 | 11:24 PM
fast_daddy_car's Avatar
Both
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
Brandle34
Sep 23, 2015 07:20 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
