>>ANGLE HEADLIGHTS UP??<<
Old Jul 9, 2006 | 12:07 AM
HondaVtec21's Avatar
I recently changed my HID Bulbs, and I think they are angled too low to the ground. I can't really see far with them and I was wondering if theres a way to angle them up to fix this problem. Any solutions will help!!
Thanks!~
Old Jul 9, 2006 | 02:10 AM
MarbleGT's Avatar
'08 MX5 GT 6spd.
nope, there is no way to angle the headlights
Old Jul 9, 2006 | 08:27 AM
dabusabus1's Avatar
lol
Old Jul 9, 2006 | 05:16 PM
htown's Avatar
3-piece FTW
You can angle the beam pattern by adjusting this screw on the back of the headlight. It should be a 10mm bolt. I believe if you tighten the screw clockwise it will move up and counter-clockwise it will move down. Make sure you're 20 feet from a wall before doing so for best results.
Old Jul 10, 2006 | 07:51 AM
fuzzy02CLS's Avatar
I aimed mine a little up after I lowered the car.
Old Jul 10, 2006 | 11:13 AM
Excelerate's Avatar
Former Sponsor
Be careful not to aim it too high. It may look nicer but you will run into two problems: the light will be projecting into the sky line and you won't see as much light on the road or in front of you and if it is aimed too high you will blind other drivers and will eventually get a ticket.
Old Jul 10, 2006 | 06:02 PM
CL'er 1st & 2nd Gen's's Avatar
Acura loyal for 93mo/109k
Put your GF in the back seat?
Old Jul 10, 2006 | 07:42 PM
danielsmi's Avatar
Red face
Are you insinuating that his girlfriend is fat and that if she were in the backseat her morbid obeseness would push the backend of the car down so much so that the front would point up higher therefore angling his headlights up?? If this is the truth then let it be known that you sir are a funny man.
Old Jul 10, 2006 | 09:02 PM
SILVER-TYPE-S's Avatar
Rookie Season
Hopefully some -----> in the rearview, then
Old Jul 10, 2006 | 09:46 PM
Lord Helmet's Avatar
I'm here in spirit...
This is the adjustment screw/bolt. Like htown said a wrench OR you can use a philips head screwdriver in the hole at the top.
Old Jul 12, 2006 | 12:04 AM
little brad's Avatar
DON'T TREAD ON ME
i feel as though mine need to be raised a bit now that my car has been lowered over 3" :p
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
