ALL question and Details about MM aka RES
I'll try it,
MM has a name...RES
RES or Resonant Enhancement System is what the Mystery Mod is, and I will miss its adopted name dearly.....
Ever heard of the "intel inside"? For those of you who think its about increasing volume...I wish you luck in your quest. Its shape has been optimised (internally) for changing the way the plenum resonates in the 3800+ RPM range. The increased volume of the center plenum does help the torque band below 3800RPM but when designed wrong, looses upper end horsepower over stock. It took awhile to figure things out and many piles of scrap metal.
Additionally, the exterior has to be designed to accomodate the hood clearance and we have installed a few unwanted "power bulges" when shutting the hood or brake torqueing the motor. Of course when you change the exterior, you change the interior and this took the longest to find an acceptable balance between fitment and performance. Once again, I spoke to Tim at ACP and he is willing to supply Hoods for you experimenters on the boards.
Yes it will be in color if demand dictates....It will be Cast in a rough aluminum with a polished machined upper surface which is deep engraved with "RES" in italicized bold NASA lettering.
The part is protected by three seperate patents, one includes the design philosophy so that it can't be changed "slightly" and remarketed. We have partnered with a Patent Law firm to handle this for us....can't spend enough to protect good R & D these days.
That reminds me, naysayers, if it were a fraud, why spend the money to protect it?
The part production continues and should be available after a November test release to board members trusted by you the public and ACP.
Notes from our mule...The system makes no additional noise, has no noticible effect on fuel economy. CARB certification will be part of the November Test release of a "production example" and should proceed, well, as quickly as CARB proceeds.
I was in the Comptech booth not to "sell" my idea to them or form a cooperative with them and the S/C...I was doing what the board should do...applaud them on trying to deliver a product you all have talked about. Shad and I have worked on a few issues before and that is the extent of our "working together". We had a few laughs over how critical some booth patrons had been. We both agree that we don't know how well our products will work together.
I hope this helps answer the questions.
Syn
MM has a name...RES
Syn
mister D
I would like to take part in the November test release, I have ordered from Tim before (intake/pulley) so I do not see any problems there... just let me know upon your decision.
to me it will always be the mysterymod ...doug since i guessed what it was back in oct 1....i should be the first allowed to purchase it...to the experts:...does it make sense that if you increased the size of the intake runners that the computer would sense the need for more fuel hence making to the experts:...does it make sense that if you increased the size of the intake runners that the computer would sense the need for more fuel hence making more power...
my thought s again are a plate that goes on top of the runners that mirror there path increasing there size ...any thoughts??? certainly a 5 min. bolt on... ....and went to explain...now see i thought i might be refering to what im describing incorrectly...when i say runners im talking about those little curvy channels just under the first plate, each with a hole at the end i meant enlarging .......plus i bet i can install it in 2 minutes with my cordless
I think someone should scan the SITE archives and find out who the people were that BASHED the hell out of this guy when he first started posting here about this MOD.
Their orders will be put on permanent backorder until everyone else already has their new toy installed.
Shawn S
Shawn S
Shawn S
Shawn S
Happy CL-S Pilot
I will take a demo, make a dyno run as FREE service to the board.
And I needed in polished chrome to complement the polished Injen CAI?
A Review would be posted too.....
Order priority should be sorted via membership registration date.
“Registered: Jan 2001” here.
Shawn S
Shawn S
Blue Devil
Re: RES or M.Mod
Originally posted by caddy
Glad to hear it's all about over. Let's close the Hood on this one !
The Hood does close right ?
Brenden
Location: Somewhere between here and there, yet neither.
Re: Re: RES or M.Mod
Originally posted by WI CLTypeS
Yeah what was that about Tim will carry hoods for experimenters? Thats not for the RES/MM correct, it will fit in the stock engine bay right?
Brenden
Brenden
6 speed...
Brenden
Brenden
Yeah what will have to be done to install this purdy thing . Do we have to remove anything else other than the stock gray plastic looking thing. Also can this mod do anything bad to the engine...should I be worrying about the warrantee as well. And what about the colors...I think you need to do it in red blue and polished...that would be sweet!
Adult Supervision
Shawn S
Shawn S
So can you reproduce the MM's claimed power gains on a dyno? Everytime you run a car on a dyno you will get different results. Just because you made two back-to-back runs where the second beat the first by 20 horsepower doesn't necessarily mean it was the MM that gave it that increase. You need to show us a rack of dyno charts that show CONSISTENT gain of power.
Then I'll be sold.
Btw, if Tim carried hoods, someone could make a ram-air hood mod and sell that. I'd buy one if it looked cool.
Then I'll be sold.
Originally posted by MikeS 18
Nah, I think that is unfair. Just make them go through their only distributor, Chris Koncur! Just Kidding guys!
Then I'll be sold.
Then I'll be sold.
Originally posted by typeR
NO MYSTERY MOD FOR YOU>>>ONE YEAR!!!!!!!!!!!!btw you need to cahnge dyno shops cause i've never heard of 20 HP variances between pulls????
Point is, just because you make one run on a dyno without the mod, then you bolt on the mod and make one more run and it happens to show 20 more HP doesn't mean anything unless the next couple dyno runs ALSO show the same +20hp.
I want to see several plots with it at +20hp, then I'll buy that it actually works.
Magnetic1 has had as much as 45hp differences on back-to-back dyno pulls. It can happen.
I just want to see that this mod actually works and isn't just someone sitting around and doing dyno pulls all day until they get one that is magically 20hp more than their lowest one so they claim this mod is the reason for it. That's all.
Let's just say after Xephyr and other bullshit with parts, I'm not about to give someone $300 for something they can only CLAIM offers an advantage.
I don't need to change anything, I've never even bothered to get my car dyno'd (why would I?).
Comment:
Chris, did make a good product, it just ended up badly (condolences to all of those people that had to snack on Tums and Mylanta tables).
It is good to be skeptical, but sometimes this place gets so "tough" that it feels like a dyno, 1/4-mile sheet, notarized witness statements, and a panel of senior members is required to "approve" or "accept" some of the stuff.
So, I would hope that some of the folks here would dyno the product and might even test it in the winter when it is cold (Ok, I’m just curious about the air density $hit…)
I am curious where you saw the +25HP difference in pulls. As a note, if a lot of members DID NOT see the claimed gains, Tim (who is very reliable) would be handling a lot of returns and a lot of people would be looking rather bad.
So, yes, I guess we will all see soon enough (statement of the obvious)...
-- WHO PLANS ON DOING BEFORE AND AFTER DYNOS???
Doug, glad to hear you were able to show the product to at least a couple people at SEMA. Add me to the list of people that are very interested in this product. I guess the $300 is worth it then since you had to get the internal structure just right in order to provide a resonance charge that actually benefits the car. My only problem is, I already have hood clearance issues with the OEM plate on the manifold, your RES plate will literally have to go through my hood in order to work . Guess I'll need a fiberglass hood with a huge hood cowl ...
For you people bitching about the color offerings you really need to chill out! How many times do you actually sit and stare at your engine bay anyways?
I mean really, I'll take a shit brown RES with puke green blotches and pink blisters if it gets me 20HP!
1 Post
Originally posted by wayneg
Congrats on all the hard work Doug. Contact me about a demo...
Thanks for a great opener to the thread. I've posted in earlier threads I'm ready for your little engineering marvel now. If your looking for a tester in Ohio (each state should have a testbed for data, eh?,) please let it be me!
Thanks again,
Jim
Community Architect
robb m.
robb m.
I would love to be the Canadian tester
thanks Doug!
thanks Doug!
...if you do that then it goes back all the way to H-A.NET....
405 posts, but my last one was on 09-19-2000 04:15 PM.
Shawn S
Shawn S
Shawn S
I was also thinking we would only allow pre-ordering to previous customers
You know, TL/CL owners who purchased their parts from ACP, thus helping with the support of the forums directly, and the support to make available more parts for our cars. Like I brought out in my
Welcome Post on A-TL
Then let the members on A-TL/A-CL who have not supported us, and bought their parts elsewhere, wait
I will post when pre-ordering will be accepted
