All Fluids
All Fluids
In the next week or so, I want to replace all fluids. this is what i can think of off the top of my head:
- Transmission fluid & all new washers
- Clutch fluid
- Brake fluid
- Power steering fluid
- Coolant
- Motor oil
am i forgetting anything?
- Clutch fluid
- Brake fluid
- Coolant
- Motor oil
lol at blinker fluid
The brakes will be the hardest. You'll have to bleed each wheel with new fluid till only new fluid comes out the bleed screw.
The power steering is easy. Take the hose out of the bottom of the tank, & let it drain out. You can remove the tank to clean inside it & reinstall. Add new fluid & your done. Use only Honda fluid for this.
Clutch is the same way, but use DOT3 or higher brake fluid. You could bleed it to if you wanted. It doesn't hold very much fluid.
The trans use either the GM syncromesh or the Honda fluid.
Wiper fluid your forgetting. May want to run a bottle of fuel cleaner through the gas tank.
B A N N E D
Location: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
with the brake fluid use a turkey baster to get the most u can out of the blake fluid res the refill with new fluid (i used castrol GT LMA) and bleed front driver front passenger rear passenger rear driver bleed each till u see new fluid move to the next one..
with ps fluid i used a turkey baster to get it out of the res then turned the key but did not start the car and turned the wheel each way the more i turned the more that pumped out of the brak system into the res. with tranny i know on autoo its easier then oil pull tranny plug drain 3 quarts refill 3 quarts in filler drive repeat 3x..
SidhuSaaB
05-30-2020 12:40 AM
