Alignment problems
Old Feb 6, 2002 | 04:35 PM
ComptechType-S's Avatar
Time to POWER UP!!
Alignment problems
Went to get my car aligned today and my rear camber was 4.2 degree off. From what i heard (at diff stores) there in no camber kit for our car, only a adjustable control arm (lowest price was $130 each). Anyone have a camber problem after installing springs? If so what did you do to fix the problem?
Old Feb 7, 2002 | 04:25 PM
Time to POWER UP!!
Damn! Did any of you get a alignment after installing springs?
Old Feb 7, 2002 | 04:31 PM
Zapata's Avatar
Cost Drivers!!!!
There is a camber correction kit for the rear but not for the front. Check out www.autocarparts.com
Some people have had to get a camber kit and others have not.
Old Feb 7, 2002 | 05:08 PM
mcdanjw's Avatar
I had to get the camber kit... it is made by Specialty Products I think.
I chewed through a set of Pirelli's in 6 months without it.
ACP has the rear kit for 175 or so I think...
Old Feb 7, 2002 | 07:02 PM
Jens H.'s Avatar
retired
4.2 degrees wow that car must be lowered quite a bit.the worst I have seen is 1.1 degrees beyond allowable limits what type of springs were installed.Comptech carries camber correction kits but I am not sure if they will correct that amount.Jens
Old Feb 7, 2002 | 07:06 PM
EricL's Avatar
Sounds kind of extreme...
Could a suspension piece be bent????
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
