Alignment after Eibach Anti-Roll Kit necessary and price?
Old Jun 23, 2004 | 05:48 PM
Amoeba's Avatar
Best D-Line in the NFL
From: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
Just got an alignment for the springs and now Im getting eibach sways in soon, will I need an alignment after the sways installation? Also should I give the guys lithium grease so I wont have any noise problems later on. How much should installation be...it says on the directions from eibach it takes 3 hours...
Old Jun 23, 2004 | 06:01 PM
Sly Raskal's Avatar
naw, dont' need an alignment after sways are installed.
as for the lithium grease, i'm not famliar with that, so i can't answer that question.
Old Jun 23, 2004 | 06:04 PM
Amoeba's Avatar
decent price would be?
Old Jun 23, 2004 | 06:13 PM
NiteQwill's Avatar
Adventurist.
Takes 30 minutes. Eibach sways come with 2 lithium grease packets.
Old Jun 23, 2004 | 06:31 PM
phipark's Avatar
Not Asian
Eibach sways come with lithium grease. Definitely shouldn't take 3 hours. Most shops around here charge about $80 for installation, but they are very straight foward as a DIY. THe hardest part is getting the nuts off for the first time. They can be a real bitch.
Oh, and you won't need an alignment afterwards. Mine didn't at least.
Old Jun 23, 2004 | 06:54 PM
EricL's Avatar
Got lithium?
Use the lithium -- good stuff.
Aligment == no... not needed on the CL/CLS...
http://www.cncusa.com/lithium/
THIS:
Is good for:
And, also for:
And, even for bipolar CL owners (... I love my CL ... I hate my CL ... I love my CL ... )
:P
Old Jun 23, 2004 | 09:02 PM
rezurex's Avatar
drop em like its hot
THIS:
Is good for:
And, also for:
:P
Old Jun 23, 2004 | 09:16 PM
darrinb's Avatar
///M POWER
installation time all depends on how long it takes to get the stock ones off, my sway bar install took nearly 6 hrs
Old Jun 23, 2004 | 09:43 PM
danny25's Avatar
^ I stripped a couple of the bolts and had to go buy a new socket just for that. But once they were off it was simple.
Old Jun 23, 2004 | 10:07 PM
Amoeba's Avatar
Well if Im paying these guys...Im gonna make em give me a flat rate, and itll be tough luck for them if that happens i got 20k on it so the bolts may be a problem.
Old Jun 24, 2004 | 08:17 AM
fuzzy02CLS's Avatar
No alignment. Use the grease that came with them. I installed mine with the help of a friend. Took about 30 minutes. I had access to a lift though.
Old Jun 24, 2004 | 09:26 AM
Amoeba's Avatar
Fuzzy you still got access to a lift...Ill give you some money to help me put em on if your up for that.
Onyxthecat
Oct 18, 2016 02:05 PM
jspangan
ILX
19
Aug 30, 2016 05:37 PM
Zonian22
Nov 14, 2015 01:20 PM
Zonian22
Sep 2, 2015 08:19 AM
