AfterMarket Radio Help
Old Sep 5, 2006 | 05:44 PM
BRIANOHSOCOOL's Avatar
Fastest Stock CLS 6sp
Exclamation AfterMarket Radio Help
welll guys i just got my cl the other day i hate the bose radio thats in it i want to put my alpine mp3 player in it is there alot of bull crap in getting it to work with the bose amp
Old Sep 5, 2006 | 07:04 PM
BigLizard's Avatar
Moderator Alumnus
Any deck will not work with the 4 main Bose speakers or AMP. You will have to upgrade everything except the tweets. A 25000 hertz breaker connection will cutoff any bass that could run to the tweets.
The most fun is, wiring the rear 6x9s. The entire interier(sp?) needs to come out to do it.
Good luck
Yes, it is a PITB to put in a new deck because the front panel and everything attached to needs to come off in order to hook up the deck.
EDIT: I need to read the top thread discussion before I talk.
Old Sep 5, 2006 | 07:50 PM
fuzzy02CLS's Avatar
Audio forum here.....
https://acurazine.com/forums/audio-video-electronics-navigation-22/
Old Sep 5, 2006 | 07:56 PM
Landocommando12's Avatar
I did a lot of research on this before I installed mine because I didnt want to have my car torn apart and have it not work, and have to figure it out with it torn apart... I bought a Metra wiring harness and dash kit (Both came together on ebay for 25 bucks shipped). Wired up the harness and installed my Indash DVD player. It worked. I had heard from some people that it wouldn't, and some that it would. I went to Rollin' Sound and asked their install guy and he said as long as I didn't change out the speakers, an aftermarket deck would work with the amp. He was right. Now he said if I were to leave it hooked up through the Bose amp, but tried to change to different speakers it wouldn't work, so I am still using the Bose speakers, and it sounds way better than it did with the Bose deck. DVDs sound really good on it. IT WILL WORK. Search on ebay for Metra wiring harness and you should be able to find one.
Good luck!
Old Sep 5, 2006 | 08:26 PM
CleanCL's Avatar
not sure what some people are sayiing, but i can remove the oem radio is liek 15 mins, and you just need the wiring harness and metra kit and it will work with your stock amp and speakers.
Old Sep 5, 2006 | 09:16 PM
BigLizard's Avatar
Moderator Alumnus
The Bose AMP is powering out 1 OHM to all the speakers, most head units can take between 4 - 8 OHMS. Eventually the deck will blow. It's better safe than sorry. 1 OHM is too much for any aftermarket deck.
Old Sep 5, 2006 | 09:32 PM
01CLKID's Avatar
I8URV8
WOW! really I have never heard this before. I've had mine in for I guess a year now no problems yet If it blows oh well its inexpensive and I'd like a newer one that has that usb ipod connection.
Old Sep 5, 2006 | 09:35 PM
BigLizard's Avatar
Moderator Alumnus
My head unit has the ipod hookup plus satelite ready
Old Sep 5, 2006 | 09:47 PM
CLean 3.0's Avatar
CLeanest in its CLass
that doesnt make any sense since the HU is sending signal to the amp then the amp to the speakers, it doesnt make sense that the amp would kill the HU. i put in a in dash dvd in my cl and ran with the bose amp and speakers for a good while, now im up to infinity speakers all around still powered by the bose amp and still no problems.
Old Sep 5, 2006 | 10:19 PM
BigLizard's Avatar
Moderator Alumnus
I'm not denying the fact that the deck sends the signal to the amp and the amp out to the speakers. But any power left over gets sent back to the deck, and if it's too much it can blow the deck.
----->>>Clarifying!
Bose speakers are usually 1 or 2 ohm(sorry). A 1 or 2 ohm load to aftermarket stereos looks like a shorted speaker. This will cause the stereo to rapidly heat up and may damage the output stages.
Please don't take this as a SA post.
4drviper
Apr 23, 2025 07:13 PM
dirleton
Aug 6, 2024 08:19 PM
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
