Aftermarket Radiator...
Old May 4, 2006 | 01:15 PM
CleanCL's Avatar
My radiator is going to need to be replaced soon and i'd rather go aftermarket if possible (obviously). i think i saw allmotor was going to test out a spoon/mugen, but i don't think it ever amounted to anything. the TL guys are having custom ones made, but i'm not sure if those will fit the CL. anyone have any input?
Old May 4, 2006 | 01:18 PM
VeeralS05's Avatar
I NEED MONEY!
I believe Spoon sells a radiator, but I'm not sure it will fit on our cars...
Old May 4, 2006 | 01:52 PM
CleanCL's Avatar
they both do, and their both pretty expensive. i was going to call around to some local places to see if i can use a universal aluminum radiator and just add the pipes in the right direction for me.
Old May 4, 2006 | 02:42 PM
fuzzy02CLS's Avatar
Why wouldn't you get a stock one? The CLS doesn't have any cooling problems. Just looks?
Old May 4, 2006 | 03:44 PM
CleanCL's Avatar
i wouldnt mind the weight reduction if possible. that's all. why go stock when you can go aftermarket for something better? just seein if there are any other options.
Old May 4, 2006 | 04:38 PM
cltypeSLOW's Avatar
Don't Mess With Texas
OEM works...i say stay with it. save your money for a better mod.
Old May 4, 2006 | 05:55 PM
CleanCL's Avatar
i'm running out of better mods oh well, ebay it is.
Old May 4, 2006 | 07:20 PM
mrsteve's Avatar
2003 TL-S Radiator: 19010-PGE-A51
2003 CL-S Radiator: 19010-PGE-A51 or 19010-PJE-A51
Sounds like if the TL guys are having them made you should jump on it.
Old May 4, 2006 | 07:32 PM
shinybluecls's Avatar
shift@8k
where does it say that the tl guys are having one made? I tried doing a search came up with nothing. Koyo makes one for our cars but its just an oem replacement .
Old May 4, 2006 | 07:38 PM
VeeralS05's Avatar
I NEED MONEY!
Interesting... does anyone have a link to the thread about the TL Aftermarket Radiator?
Old May 4, 2006 | 08:00 PM
ThinJim's Avatar
the stock one is more than adequate, save your bucks for the tranny upgrade. I've had no issues with overheating,,,as the saying goes, why re-invent the wheel. as for weight savings it's marginal at best and doesn't justify the expense. hows the build coming?
Old May 4, 2006 | 08:20 PM
brianlin87's Avatar
ASM I.S. Design FTW.
i tried navigating around the TL sxn and found nothing either.
Old May 4, 2006 | 08:39 PM
Allout's Avatar
Blown is Best
CleanCL - Since you're an auto, if you don't have a tranny cooler, you should definitely go that route to give yourself some additional cooling capacity. You could even bypass the stock tranny cooler and have the external tranny cooler do the work to reduce the amount of heat introduced into the stock cooling system. Go with at least a 24K GVW cooler.
I'm not fully convinced that the stock radiator has sufficient capacity for FI. I think one of the reason why the Mugen Mods are successful in adding HP is by lowering the water temp in the radiator so it has sufficient heat capacity to keep the motor at a temp to not pull timing. In other words, my theory is that the Mugen cooling mods give the motor a head start on pulling heat off the motor. With a properly sized radiator, it should be able to keep up with FI on it's own. If I were to guess, if you ran several back to back runs, you would see the water temp rise. I don't have a scan tool to test this but it would be interesting to find out.
I've always been of the mind to build in extra capacity into the radiator so as it loses it's efficiency, you've still got a margin of safety. Radiators will always lose a bit of capacity over time through internal and external debris.
Old May 4, 2006 | 08:40 PM
CleanCL's Avatar
what no one searches the 3G Forums? https://acurazine.com/forums/showthr...light=radiator i'm all over the place
on a side note:
3G TL Radiator: 19010-RDA-A51
Old Jul 27, 2006 | 05:55 PM
njzprettyboy's Avatar
I too have started a search for an aftermarket radiator, but have found nothing. unfort koyo doesnt make one, only for the 97-99 CLs...would that fit maybe
Old Jul 28, 2006 | 08:16 AM
CleanCL's Avatar
koyo does make one, but its not the racing all aluminum one, its jsut a standard radiator. its the one i ended up buying.
KOYO Part # 19010PGEA51
its $160 at rockauto.com
Old Jul 28, 2006 | 10:01 AM
Excelerate's Avatar
Former Sponsor
If you need a KOYO radiator let me know. I can usually get them overnighted at a decent price.
On a side note, if I had seen this trhead 2 months ago I would recommended Griffin to you (http://griffinrad.com/). Apparently they do a lot of custom radiators. All you would have had to do was give me some specs and I could have had an aluminum radiator made up for you.
Old Jul 28, 2006 | 10:28 AM
cleancl--do you think that it is an improvement over the stock radiator? my oem one has like 100K on it...and I am adding an SC now...
Old Jul 28, 2006 | 10:29 AM
how much do you think a custom one would cost?
Old Jul 28, 2006 | 12:56 PM
CleanCL's Avatar
njzprettyboy - not sure, the motor isn't running yet, lol. but from design standpoint it looks just like stock. my car had 80,000 and i could see the seems starting to go.
excelerate - let's talk about this griffin radiators.
Old Jul 28, 2006 | 01:24 PM
Excelerate's Avatar
Former Sponsor
LOL. Shoot me an email with the specs on the radiator and I'll talk to Griffin.
Old Jul 28, 2006 | 03:02 PM
exc. i am interested too. i called griffin today, as well as ron davis. They both qouted me 5-700. This would include an internal ATF cooler like the OEM one...both companies make radiators that look outstanding. I am planning on writing sponsorship proposals to both, but not too sure if that will pan out the wya i want it to.
cleancl, im sure we could get a better price if we both got one. im not sure how many other folks would be interested in getting one done as well...
Old Jul 28, 2006 | 04:11 PM
CleanCL's Avatar
do i sense another groupbuy? we might be able to get 5 people, the 3G TL guys are also very interested in one as well.
Old Jul 28, 2006 | 04:24 PM
hmm, 5 people @ $500 each would be sweet. A little optimistic I know, but that would be the price point at which I would be most interested. Anyways, Fluidyne does not do custom build to order deals, at least not for normal street cars. The setup in the 3G forum is a little costly at 700$+, and since we have diff radiators, Im not sure how well it would workout. I think we will have a tough time rounding up 5 people for this though. Glad to see there is at least 1 more though
Old Jul 28, 2006 | 04:37 PM
digemini's Avatar
://DC BLK CLs 6speed
I am interested. I have been looking at having a universal aluminum radiator with a built-in oil cooler fitted. I'm getting boosted and I think the extra cooling will help keep the temp lower
Old Jul 28, 2006 | 06:18 PM
Sounds awesome. Upon further inspection, the 3rd gen guys is costing them $850--at that price I would not be interested/
Old Jul 28, 2006 | 09:07 PM
danielsmi's Avatar
Um I don't know if you a have a manual or not CLeanCL but this is what I read here
http://www.nolimitmotorsport.com/koyo/
"All Koyo Radiators are made for manual transmission's only. If you have an automatic, with oil cooler, this will NOT work."
Also I would highly recommend a tranny cooler if you don't have one. I just installed mine last night and am glad I did.
Old Jul 28, 2006 | 11:00 PM
CleanCL's Avatar
mine is clearly stamped Koyo, just go to rockauto.com and search for 2001 acura cl type s, its listed right there.
and i'm having a tranny cooler installed as well.
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
kb1rl
Sep 30, 2015 10:17 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
