after 141529 miles...
Old Jan 9, 2010 | 04:00 PM
HappyVirus's Avatar
Finally the tranny gave up on me
Was driving fine until yesterday, started the car this morning, and car just can't shift from 2-3 and above. Whats worse is...I can't even reverse....
I went to a local tranny shop as I'm probably out of luck for the Acura warranty
I was quoted 1300 for the tranny (including labor)
Any opinions?
Old Jan 9, 2010 | 04:03 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Is the 1300 for a rebuild or for a used tranny replacement?
Old Jan 9, 2010 | 04:08 PM
HappyVirus's Avatar
Rebuilding it. He said there's a one year warranty as well. What are the usual prices people pay for trannys?
Old Jan 9, 2010 | 04:25 PM
1300 and a year warranty is not bad.
As long as their is not any bill increases when you pick up the car.
He really don't know what he's got till the tranny is cracked open.
asked that av6 guy what is his going rate is for the rebuild
Old Jan 9, 2010 | 04:27 PM
HappyVirus's Avatar
Any idea how long rebuilt trannys last? or does that vary from everyone (like any other auto tranny)
Old Jan 9, 2010 | 04:33 PM
p.diddy's Avatar
bingo.
Old Jan 9, 2010 | 05:55 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I payed 3 k for a tranny rebuild and new torque converter?
ASk the guy if that price includes torque converter ..
I heard of ALOT of people getting prices TOO GOOD to be true and said ok and when they took the tranny out of the car and opened it up they say it will be $1500 more cuz blah blah blah.. and if u tell them to go fu^& themselves they will tell you if u want us to put the tranny back togethere and into your car that will be $800 so u r screwed..
DONT get screwed and DO NOT go to AAMCO cuz they will lowball u and them F//K u !!
GO on ATRA . com and find a reputable place!
$1400 is too good to be true and prob is!
Old Jan 9, 2010 | 05:56 PM
StonedCL's Avatar
B A N N E D
I called like 10 places in NJ area and prices for complete rebuild with torque converter and all work was anywhere from $2400 - $3500
Old Jan 9, 2010 | 06:30 PM
HappyVirus's Avatar
Hm...thats something I didn't want to hear...heh
I didn't go to AAMCO, but went to a local shop that I knew. When he plugged the computer, it had something with
Shifter issue(forgot the actual wording)
gear ratio (again..not exact)
I'll call and ask...hoping I don't get screwed x.x
Old Jan 9, 2010 | 06:54 PM
Ask people around in your area,not shops but a few diffent people and see if you find people agreeing with a certin trans shop.
It dont have to be a fancy shop,a world popular shop, just a shop that does a correct job and stands behind their work.
Word of mouth counts for alot.
Old Jan 9, 2010 | 07:00 PM
friesm2000's Avatar
B A N N E D
THANK GOD, they are such butchers
and for the codes, kinda need code numbers to be more helpful, but
shifter issue; not quite sure without a number
gearratio; proably incorrect gear ratio, which means more then likely the computer is detecting gear (actually clutch pack) slippage; which is the output shaft is not turning the correct number of times for how many times the input shaft is turning
Old Jan 10, 2010 | 03:30 AM
civicdrivr's Avatar
How about a 3rd gen or Oddysey tranny? Itll cost about the same, maybe alittle more but it will be worth it in the long run.
Old Jan 10, 2010 | 02:18 PM
phee's Avatar
I got the Shifts
dont do it. contact paul and have him swap in a 3rd gen tranny. orrr call acura. u never know what they can do for u.
use all options to save money first
Old Jan 10, 2010 | 03:06 PM
brian6speed's Avatar
Lone Wolf
this is the option i would take. might be a little more work but will be beneficial in the long run.
Old Jan 11, 2010 | 01:09 PM
HappyVirus's Avatar
I got in contact with them, and they said the 1300 was including the torque converter and all the labor. To be honest, it sounds a little too good to be true.
I would much like to do what most of you suggested, and try to convert/put in the 3rd gen tranny, (or even go for the 6MT conversion)...but right now, I'm afraid that can't be one of my options :S
Just for the thoughts...how much should the 3rd gen tranny or the 6MT conversion cost?
Old Jan 11, 2010 | 01:23 PM
p.diddy's Avatar
i bet after they open it up the charges will go up.
Old Jan 11, 2010 | 01:25 PM
Lone Wolf
cant you just get a oddysey tranny from a junk yard or wreck for cheap?
Old Jan 13, 2010 | 06:00 PM
HappyVirus's Avatar
I picked up the car today.
Total price: 1400.
They said they rebuilt the tranny, and also swapped out the rear motor mount.
Also, they gave me 1yr/12000mile warranty on the tranny. So far, I've driven for maybe 20-30 miles since the fix.
Was 1400 a good price for the fixed tranny and the rear mount?
Old Jan 13, 2010 | 07:01 PM
good deal 4 sure.
Now remember the mileage and see how long this one last.
They replaced the convertor too right.
Old Jan 13, 2010 | 09:09 PM
HappyVirus's Avatar
Yea they said that they replaced the torque converter.
*is there way to check? I'm just taking their word for it*
Old Jan 13, 2010 | 09:16 PM
friesm2000's Avatar
B A N N E D
pull the bottom cover plate, next to the oil pan, and normally when they "rebuild/make it", they paint it, but they may have still left it unpainted though (normally factory ones are just left unpainted)
misterdannyboy
Aug 13, 2008 04:09 AM
stillhere153
Jun 17, 2008 08:45 PM
datplayaz
Apr 27, 2008 08:36 AM
VeeralS05
Aug 20, 2004 11:49 PM
