AEM Pulley Problems
Old Aug 3, 2001 | 11:34 AM
Dizzy's Avatar
Prez & GC, .Net
AEM Pulley Problems
AEM Pulley's are possibly destroying our alternators and draining our batteries.
http://superhonda.org/board/showthre...threadid=49224
http://superhonda.org/board/showthre...threadid=18762
Just wanted to get you folks updated. How many have the AEM pulley's installed? How long? Do you have an aftermarket audio system as well?
On the Accord V6's the AEM alternator pulley is presently wreaking havoc on our alternators. Already, at least 8 SHO members have had to replace their alternators AND battery when the alternator pulley doesn't produce enough power to run the acessories.
For all Acura-CL folks. Check your the volatages coming from your alternator, before AND after installing the AEM alternator pulley. The Accord V6 uses a Delphi (GM TRASH) alternator.
If you haven't installed your AEM pulley, please measure the voltages going into your battery. That way, the folks who already have their pulley's can measure there's and we can figure out if the pulley is generating enough energy to recharge the battery. On the Accord V6....w/ the pulley in, it doesn't recharge enough....hence, batteries die within 6 months.
As a moderator for superhonda Accord V6 forum, I'm giving a negative recommendation on purchasing AEM Pulley's until AEM finishes their investigation. Too many folks have had their alternators and batteries die on them and there are series product liability issues now. Complaint letters/emails have already been sent to AEM and they replied that they are investigating the problem.
Dizzy
Old Aug 3, 2001 | 11:38 AM
KCPreki11's Avatar
Originally posted by Dizzy:
<STRONG>AEM Pulley's are possibly destroying our alternators and draining our batteries.
Dizzy</STRONG>
Thanks, it's nice for somebody from another board to actually post something informative about our cars and not negative.
Old Aug 3, 2001 | 12:25 PM
xenon7's Avatar
Xe- For Better Hwy Vision
AMEN Brother!
Old Aug 3, 2001 | 12:28 PM
macon's Avatar
Thanks for the warning.
Old Aug 3, 2001 | 12:52 PM
rdsandy's Avatar
Why would it suprise that the battery isn't charging?? the whole concept of pulleys is to reduce parasitic power losses from the drivetrain. If you reduce the power required to charge the battery you get more power to the wheels. Of course the downside is you ruin your electrical system. The is always a tradeoff between speed and comfort.
Old Aug 3, 2001 | 01:09 PM
MtBikR's Avatar
I haven't noticed any problem with mine. I also haven't measured any sort of electrical currents. I was wondering though how the pulleys reduce the power loss (is it thier diameter or is the belt they use different) thanks
Old Aug 3, 2001 | 01:22 PM
spiroh's Avatar
The diameter.
Originally posted by MtBikR:
<STRONG>I haven't noticed any problem with mine. I also haven't measured any sort of electrical currents. I was wondering though how the pulleys reduce the power loss (is it thier diameter or is the belt they use different) thanks</STRONG>
Old Aug 3, 2001 | 01:40 PM
SSMAN's Avatar
The output of the Accord V6 alternator is less than a Type-S CL/TL (105A vs. 120A). I have driven 3000 miles since installing the AEM pulleys, and I have no problems.
Old Aug 3, 2001 | 01:44 PM
Infamuz's Avatar
Retired Post Whore
I was about to install my pulleys tomorrow. I was just thinking of changing the power steering pulley, and not the alternator was because I have a system in the car. What should I do?
Old Aug 3, 2001 | 01:49 PM
WebToker's Avatar
I have had my pulleys for over 4k miles and no problems what so ever. ;-)
Old Aug 3, 2001 | 01:53 PM
Infamuz's Avatar
Retired Post Whore
Hopefully there shouldnt be a problem.
Old Aug 3, 2001 | 01:56 PM
BNut's Avatar
S/C'd Accord Coming Soon!
I don't know about the amperage, but the voltage is way too low when the car is at idle. I've had my pulleys for almost 1 year with almost 20,000 miles and no probs BUT I also spend a lot of time on the freeway where my battery has a chance to be fully recharged. People that drive a lot of short trips or spend a considerable amount of time in stop and go traffic are definitely at risk.
You can buy a voltmeter for 20 bucks and check your voltage at the battery with the car turned off (should be close to 12.5 volts) with the car running at idle (should be b/w 13.8 - 14.3 volts) and with various accessories enabled. Your voltage should always stay in the 13's but with my car at idle with NO accessories turned on, I'm at 12.7 - 12.8 volts. Just turning on the A/C can drop my voltage down to 12.4 - 12.5. Turn on the headlights and I'm down to the 12.2 area.
Don't assume your car is ok because your battery hasn't died yet, CHECK IT OUT!!! We need to let AEM know if they were a little too aggressive with their under driving of the alternator.
Old Aug 3, 2001 | 01:58 PM
Dizzy's Avatar
Prez & GC, .Net
U'd probably want to check the voltages to make sure. Since the CL alternator seems to be stronger, it should be properly recharging the battery. I drove about 3500k before my alternator died.
A properly designed pulley should give you the gains and STILL produce just enough power to recharge your battery. Like I said before, the only way to be 100% sure is to check the voltages.
Dizzy
Old Aug 3, 2001 | 02:02 PM
spiroh's Avatar
I like aggressive =)
Originally posted by BNut:
<STRONG>I don't know about the amperage, but the voltage is way too low when the car is at idle. I've had my pulleys for almost 1 year with almost 20,000 miles and no probs BUT I also spend a lot of time on the freeway where my battery has a chance to be fully recharged. People that drive a lot of short trips or spend a considerable amount of time in stop and go traffic are definitely at risk.
Don't assume your car is ok because your battery hasn't died yet, CHECK IT OUT!!! We need to let AEM know if they were a little too aggressive with their under driving of the alternator.</STRONG>
Old Aug 3, 2001 | 02:17 PM
Infamuz's Avatar
Retired Post Whore
SPIROH, you have a system in your car?
Old Aug 3, 2001 | 02:30 PM
NOVAwhiteTypeS's Avatar
You also got to realize the TypeS has a stronger alternator than teh cl-p and accord.
and plenty of people hadn't had a problem.
Old Aug 3, 2001 | 02:33 PM
Rod's Avatar
Rod
Originally posted by NOVAwhiteTypeS:
<STRONG>You also got to realize the TypeS has a stronger alternator than teh cl-p and accord.
and plenty of people hadn't had a problem.</STRONG>
Also, weren't CL-S specific pulleys made? Hopefully these were better designed than the Accord's.
Old Aug 3, 2001 | 02:34 PM
spiroh's Avatar
Yes I do. I had pulleys on my GS-R for over 20k miles with a system, and had only 1 incident. I was bumping the music on idle, and I turned the car off. When I tried to restart it, it didnt have enough power. As long as you rev up your car you will not have any problems. I'm still waiting for my pulleys to come in, on my Type S. RED AEMs are backordered for 4 weeks.
Spiro
Originally posted by Infamuz:
<STRONG>SPIROH, you have a system in your car?</STRONG>
Old Aug 3, 2001 | 02:35 PM
spiroh's Avatar
CL-S/CL-P use the same model #.
Originally posted by Rod:
<STRONG>
Also, weren't CL-S specific pulleys made? Hopefully these were better designed than the Accord's.</STRONG>
Old Aug 3, 2001 | 02:36 PM
Infamuz's Avatar
Retired Post Whore
You guys better tell me soon. I have a 1400 and 800 watt amp in my car with 2 1 farad capacitors. Should I still change the alternator pulley in the car? I also put a Sears Die Hard Gold in my car too..any suggestions?
Old Aug 3, 2001 | 02:37 PM
Rod's Avatar
Rod
Originally posted by spiroh:
<STRONG>CL-S/CL-P use the same model #.
</STRONG>
But they're still different form the Accord pulleys, correct?
Old Aug 3, 2001 | 02:53 PM
Ogolden1's Avatar
Oh...Behave!
Larger diameter pulley = SLOWER rotation = less power generated = slow drain on battery!
Why risk it for a MEASLY 4-5 HP!!!
Old Aug 3, 2001 | 02:57 PM
spiroh's Avatar
Are they class D or class ab amps? Class Ds are more effecient, and wont drain as much as AB would. I have a 600w, and a 1200 w amp in my car. One being class D, and the other class ab. I am gettign the pulleys installed in my car. I dont think I will run into any issues. I cant guarantee anything until I get them installed though.
Spiro
<STRONG>You guys better tell me soon. I have a 1400 and 800 watt amp in my car with 2 1 farad capacitors. Should I still change the alternator pulley in the car? I also put a Sears Die Hard Gold in my car too..any suggestions?</STRONG>
Old Aug 3, 2001 | 03:05 PM
BNut's Avatar
All I ask is that you guys check your voltage at the battery when your car is at idle... with and without accessories (stereos, headlights, AC, defroster, etc) turned on.
Old Aug 3, 2001 | 03:35 PM
<STRONG>All I ask is that you guys check your voltage at the battery when your car is at idle... with and without accessories (stereos, headlights, AC, defroster, etc) turned on.</STRONG>
according to my escort 8500 the voltage meter says 13.1
Old Aug 3, 2001 | 03:46 PM
wayneg's Avatar
Guys- its not the voltage you need to check- its the amperage. The oem system is designed to supply enough amps at idle to handle the full electrical load. When you change the pulleys, the output drops at idle because the speed decreases thus reducing the output. You can read 13.0 volts and still only have less than 5 amps out. We have installed the pulleys and I personally did see see a performance increase that you could feel. They are probably best for racing applications- for the street with amps,systems,lights and cruisn'- who knows?
Old Aug 3, 2001 | 04:21 PM
moomaster_99's Avatar
From: Somewhere between here and there, yet neither.
Originally posted by wayneg:
<STRONG>Guys- its not the voltage you need to check- its the amperage. The oem system is designed to supply enough amps at idle to handle the full electrical load. When you change the pulleys, the output drops at idle because the speed decreases thus reducing the output. You can read 13.0 volts and still only have less than 5 amps out. We have installed the pulleys and I personally did see see a performance increase that you could feel. They are probably best for racing applications- for the street with amps,systems,lights and cruisn'- who knows?</STRONG>
I just make sure my car is idling if I'm playing music....
Also...if you guys are worried...get a dry cell battery.
Old Aug 3, 2001 | 04:32 PM
Shawn S's Avatar
Just for reference, I DON’T have the pulleys, but when I am sitting at a RED light idling at night with the tunes CRANKING my headlights & dash lights tend to dim to the BASS beats.
I have a single KICKER 400 Watt AMP.
I don’t have any power Caps, but I probably should get one.
I wouldn’t even think of putting pulleys on this car if you are running any kind of system with even a single AMP.
Shawn S
Old Aug 3, 2001 | 07:12 PM
WebToker's Avatar
Just FYI I have a 300w amp on my system and I blast my radio all the time. Again, no problems yet so far.
Old Aug 3, 2001 | 07:14 PM
[VTEC]TL's Avatar
RWD convert
What type of alternator do the regular TL/CL's have?
Allan
Old Aug 3, 2001 | 07:26 PM
EricL's Avatar
Originally posted by [VTEC]TL:
<STRONG>What type of alternator do the regular TL/CL's have?
Allan</STRONG>
CL -- 105 AMP max
CLS -- 120 AMP max
Comment:
The charging system is more complicated than some people think. What may work well on one configuration of car, may not work too well on another.
Some of the newer alternators are combined with "smart logic" to charge the battery during deceleration (if you are going to slow down, why not let the alternator help out...). These systems will try to boost the charge at idle IF there has not been enough deceleration to give the battery enough of a charge.
If someone has an older battery (a marginal one) or a ton of electrical load above factory specs, they are probably asking for trouble if they are playing their 400-Watt amps at full volume for extended idling periods.
[ 08-03-2001: Message edited by: EricL ]
Old Aug 3, 2001 | 07:29 PM
BNut's Avatar
Currently I have TWO amps, a 350 watt sub amp, and a 240 watt mids/highs amp. I've never had problems, but I haven't tempted fate either... I turn the radio down when I'm at a stop light, or off if I get stuck in a traffic jam. If I'm in the middle of a really bad wreck where traffic isn't moving, I'll occasionally slip the gear into neutral and reve the engine to 1,500rpms to make sure the battery is getting some juice.
Wayne how can we measure the amperage that our our alternator is producing? My volt meter can only measure up to about 10 amps.
Old Aug 3, 2001 | 07:32 PM
EricL's Avatar
<STRONG>Currently I have TWO amps, a 350 watt sub amp, and a 240 watt mids/highs amp. I've never had problems, but I haven't tempted fate either... I turn the radio down when I'm at a stop light, or off if I get stuck in a traffic jam. If I'm in the middle of a really bad wreck where traffic isn't moving, I'll occasionally slip the gear into neutral and reve the engine to 1,500rpms to make sure the battery is getting some juice.
Wayne how can we measure the amperage that our our alternator is producing? My volt meter can only measure up to about 10 amps. </STRONG>
Get a current shunt -- I have a few here and they have a couple of posts on two sides of a wide strip of metal. The unit will be calibrated in millivolts per AMP. The bigger one I have is good for 200 AMPS.
Look up current shunt!
Old Aug 3, 2001 | 07:34 PM
EricL's Avatar
BTW -- most of the newer amps are either class D or use very little power at low volumes. If anyone is running a class-A amp, then all bets are off...
They "good" amps have efficient switching power supplies and will NOT use a lot of power unless your ears are bleeding (or hurting).
Old Aug 3, 2001 | 07:40 PM
EricL's Avatar
Here is a link for anybody who wants to make a dirt cheap current shunt using some #8 wire...
link to (Making and Using a High Current Shunt):
http://members.tripod.com/~Wrenchbender/shunt.html
Old Aug 3, 2001 | 08:15 PM
BNut's Avatar
Originally posted by EricL:
<STRONG>Here is a link for anybody who wants to make a dirt cheap current shunt using some #8 wire...
http://members.tripod.com/~Wrenchbender/shunt.html</STRONG>
Thanks for the info, but I'm not that brave. I'd rather spend $70 at radio on something that can "safely" measure the amps than have my non-engineering azz trying to rig up something.
Old Aug 3, 2001 | 08:26 PM
EricL's Avatar
<STRONG>
Thanks for the info, but I'm not that brave. I'd rather spend $70 at radio on something that can "safely" measure the amps than have my non-engineering azz trying to rig up something. </STRONG>
Unless you buy a very expensive meter, you will end up with a current shunt that looks something like this (Sorry, I haven't looked up and don't have a current shunt for "CARS").
The picture of the shunt, is a what you will find around:
Picture:
"MKA-100-100: 100 amp 100 mv shunt"
This would give you a .01 Volt reading for every 10 amps of current draw (up to 100 amps)...
link: http://www.solar-electric.com/mka-100-100.html
Old Aug 3, 2001 | 10:59 PM
Infamuz's Avatar
Retired Post Whore
How can you tell what class is your amp? Whether it's an A or D class?
Old Aug 3, 2001 | 11:11 PM
EricL's Avatar
<STRONG>How can you tell what class is your amp? Whether it's an A or D class?</STRONG>
Believe me, if it is A class (high power dissipation at low power levels), but very low distortion, the maker will probably let you never forget it...
The class D design is a PWM (Pulse width modulator/switching) design and is very efficient. Unless I am mistaken, most of the class D makers will let you know, since the units are very efficient.
The "bulk" of the mainstream amps will use AB class operation.
An article on audio power amps/op amps:
http://www.edtn.com/analog/c018.htm
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
rangomango
California
Sep 24, 2015 05:47 PM
