AEM COLD AIR INTAKE
Old Jul 11, 2001 | 12:29 AM
EDFRO's Avatar
AEM COLD AIR INTAKE
im trying to install this thing but my logic says this thing is toooo fucking big to fit yet it is the right part... how the hell do u get this thing in?
Old Jul 11, 2001 | 12:31 AM
JRock's Avatar
Old timer
Use some KY and stroke it.
Old Jul 11, 2001 | 12:32 AM
NOVAwhiteTypeS's Avatar
http://wizardsworks.org/chod/acura
chods faq, w/ pictures.
Old Jul 11, 2001 | 12:33 AM
BBsAcuraRacing's Avatar
The real question is how the hell do you get the baffle back when you turn in your lease....
Old Jul 11, 2001 | 01:12 AM
ChodTheWacko's Avatar
Moderator Alumnus
Originally posted by EDFRO:
<STRONG>im trying to install this thing but my logic says this thing is toooo fucking big to fit yet it is the right part... how the hell do u get this thing in?</STRONG>
Did you remember to order the BFH?
And yah, if you can't get it installed with my instructions, let me know what steps need to be explained more.
That reminds me, I should make a copy of "X"'s instructions in case his site goes poof.
Old Jul 11, 2001 | 01:49 AM
pkane's Avatar
Old Fella
JZ had some good advice for me on the install. He said as follows:
The install is not so bad. Go to xephyrperformance.com and print out his directions (they are a bit different than ours, but they worked for me [the ones AEM give you suck]). The only hard part is removing the second resonator bolt. That alone took me 30min. with the car jacked up. Don't unhook the stock hoses--just stick them onto the AEM hoses and connect to CAI. A couple of other things to notice: you have to remove a small bracket on the side of the car that no directions mention, and (2) push the filter as far onto the tube as possible b/c it will protect the pipe from the bolt near its end.
Holler if you need any more help!
Pkane
Old Jul 11, 2001 | 11:52 AM
xenon7's Avatar
Xe- For Better Hwy Vision
Note:
Make sure you remove the front "Z" bracket just in front of stock air box. That will clear the path for the pipe. It requires a little more werk but, I found that using the new hoses provided by AEM really makes for a real clean looking install.
Amen on the "X's" directions. Use them
as a supplement to AEM's.
Good luck on the install!
[ 07-11-2001: Message edited by: xenon7 ]
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
hashbrown
Sep 29, 2015 12:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
