AEM Bypass Valve Broke
That's hot...
Basically hit a pothole, heard some clanking in engine bay, opened engine, heard air leaking from intake, checked it and saw that the plastic on the bypass valve was cracked. ![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
Guess I'm off to Queens Blvd. to look for some silicon hosing, unless someone in NYC has a bypass valve laying around![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Should a silicon hose with a 3"diameter and 5" length be good enough? Where can I get something like this in NYC? And people who have done this before, like Scrib, what have you guys done since? Can I just go on with the hosing (cause after using the vavle for 3 years I have seen little use for it)?
Thanks for the help
Thanks for the help
Blown LS6!!
Can't really answer your questions, but I was thinking about taking off my bypass valve and just replacing it w/ some 3" hose and a couple of hose-clamps. I'm always worried that the little rubber flaps on the bypass are letting unfiltered air into the engine. And like you said, I can't think of one time in the last 3 years w/ my car that I've submerged the intake pipe in water.
That's hot...
Originally posted by Scrib
Mine broke too and I got a silicone sleeve to replace the bypass valve.
Administrator Alumnus
Originally posted by anj2
Have you ever replaced the hose or have you just left it on?
Not sure what you mean by "hose"...
GEEZER
duct tape ownz joo
That's hot...
if i get another bypass valve, would a simple rubber hose/sleeve from home depot be good enough as a temp replacement or do i need to go the silicon route?
Re: AEM Bypass Valve Broke
Basically hit a pothole, heard some clanking in engine bay, opened engine, heard air leaking from intake, checked it and saw that the plastic on the bypass valve was cracked.![Mad](https://acurazine.com/forums/images/smilies/mad.gif)
Thanks for the help
Thanks for the help
1 Post
Mine broke too, i called AEM they said they would send me a new one and to send the old one back in the box the new one came in. In less than a week i had the new one, but i ordered the 3" AEM silicone sleve from Dean for $12 and left the new bypass valve off
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
