Advice at the track
Old Sep 28, 2005 | 12:21 AM
CL SPEED 01's Avatar
TAKE IT TO THE STREETS
Advice at the track
Hey guys. im going to the track soon. i am putting in my unorthodox Ultra Sc 12v crank pulley, and my ngk spark plugs, and im heading up there next week. I was just wondering if any of you had any advice on how i should launch my car at the track. And what psi should my tires be. last time i ran a 14.89 and i had the front at 28psi, and the back at 32psi. Is this good?
If anyone has any imput on this. please feel free to help. i need to run at least a 14.40. I don't feel like putting mods in my car and gettin .1 seconds every time.
Old Sep 28, 2005 | 01:30 AM
anyone....
Old Sep 28, 2005 | 02:29 AM
ayougo's Avatar
B A N N E D
set your tires to 27 psi ( front ) torque break and rev to 4000 then go. I recommend gate shifting also not ss turn traction control off too. you should be low 14s 14.1-14.3 ish
Old Sep 28, 2005 | 09:54 AM
johntypes's Avatar
Set your frt. tire pres. at 31# and rear at 40# torque at 1600 and work your way up untill wheel hop starts you should see 2.24 to 2.35 60ft times let us known.
Old Sep 28, 2005 | 05:00 PM
YES. just got my pulley installed. i better run a good time, or i'll be pissed and maybe buy a new car.
Old Sep 28, 2005 | 06:00 PM
Sun Diego CL-S's Avatar
says "hello to my TLX".
it's not a racecar as you well know. if you want to go fast you should've bought a car with a cheaper interior but runs quick like a the last gen's mustang gt.
Old Sep 28, 2005 | 07:38 PM
ChucksCL-S's Avatar
Go early and let the car cool off. Take off the engine cover and put a 10 lb bag of ice on the intake manifold to cool it further. Remove jack, spare tire and trunk mat. Remove everything you can. Run with 1/8th of a tank of gas if possible. Turn off VSA (traction control), stereo and climate control system. Front tires at 25, rear 35. At the line you can torque brake to 1200 or 1500 rpms and on green go but DO NOT mash the pedal, go down alittle slower to avoid wheel hop or a time wasting burnout. Do not worry about reaction time, it IS NOT figured into elapsed time. Use D3 and hold her to the floor all the way to the end. Go around and race again if you fealt the launch was bad, this time leave from idle and see what happens. Weather wise you want 50 to 70 degree air that is dry and to run on a high pressure (blue sky) kind of day. Humid warm air will slow you down.
Now some members will disagree with some of this advice, but overall I would say this will net you nearly the best there can be. Good luck!
Old Sep 28, 2005 | 10:27 PM
mrsteve's Avatar
^ Sounds good to me. Just don't torque brake until they start to drop the yellows!
Old Sep 28, 2005 | 11:27 PM
Sun diego- i know its not a race car, but i know that if i put mods in it and don't run whats expected, im gonna get mad. you know what i mean. chuck cls, nice advice. i know everything you said, but why do u want me to put the car in d3, rather than start in 1 and shift up myself????? let me know. thanks
Old Sep 29, 2005 | 12:41 AM
mrsteve's Avatar
Shifting on your own opens the door to move driver error. My quickest times were in SS mode however they were only 0.10 seconds quicker than leaving it in D4.
Old Sep 29, 2005 | 01:26 AM
yeah but what does leaving it in d3 do??? i know ur in 3rd gear when u finish the race, but won't it be better in 1.... i don't really like ss, cause when our car shifts by itself, it doesn't redline first-second gear.. that sucks a lil bit. ......what do u think i should run about....i think i should run about 14.3-14.5
Old Sep 29, 2005 | 07:39 AM
mrsteve's Avatar
Yeah that sounds about right.
And my car always went to redline from 1st to 2nd. With the supercharger sometimes it would hit the rev limiter from 1st to 2nd.
Old Sep 29, 2005 | 09:08 AM
so can someone explain why d3 would be sucha good thing to start in. if not, then its ok, i'll just try it anyways. haha
Old Sep 29, 2005 | 01:37 PM
Lord Helmet's Avatar
I'm here in spirit...
I don't think it matters. It's not gonna shift any different from D4 or D3. It's the same except when you are in D3 the tranny will never shift into 4th.
Old Sep 30, 2005 | 04:57 PM
All Mine's Avatar
I'm a Vagiterian.
Any tips for a soon-to-be SC'd auto? Or pretty much same thing as what others were saying?
Old Oct 3, 2005 | 01:56 AM
damn. i didn't get the chance to put in my new ngk iridiums in. 2 more days until i go to the track. The track i go to. is known to suck @$$. but oh well if i run a 14.4. i will be happy. cause i know that my car is doing good.
i will try launching different ways and we'll see which ways will be the best. thanks everyone
Old Oct 3, 2005 | 07:53 AM
mrsteve's Avatar
Don't torque brake. Leave off idle.
Old Oct 3, 2005 | 08:08 PM
ChucksCL-S's Avatar
^ That is correct, use two feet as the lights drop and then lift off the brake and hit the gas, but do not pound the pedal to the floor as you may spin and lose time. Get those front tires to grab. If you mess up bad just drive normally down the track and come around and line up again.
Old Oct 3, 2005 | 08:39 PM
power3dfx's Avatar
Parting out 02 Type S :(
I disagree. I know you have pulled off some really good times all around, but i find that tq braking provides a lift of the nose before forward movement. having the nose raised from the start seems to stop some of the wheelhop and takes away some of the sudden nose jump when you go from idle.
but thats from my experience, others may get better results doing it other ways. try both and see what works both. keep alternating between methods to get a good combo set up. good luck!
Old Oct 3, 2005 | 10:42 PM
mrsteve's Avatar
The transmission is made of glass. Boiling the transmission oil by brake torquing at the line isn't worth the extra 0.05 seconds off your 60' time. I pulled a 2.000 60' time off idle. You and I were very lucky with the health of our transmissions given how quick our cars are (were). Even though I never had a real problem I still wouldn't recommend something so decremental to anyone else.
Before I was supercharged I would brake torque for just a few seconds before the green. I was too afraid to do the same with the car boosted.
Old Oct 4, 2005 | 10:49 AM
OK GUYS! today is the day to go to the track .wish me luck to ride a 14.3@99mph. that is my goal. i will let you know what happens tonight or tomorrow.
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
