advantages of synthetic oil?
Darth Tator
what are the advantages of synthetic oil?
how many miles can you drive in between oil change if you use lets say Mobile One?
How much will the dealer charge me for a oil and filter change if I bring in my own oil?
Powered By HONDA
the syn oil are good becuase they will stablize the engine temperature..and reduce the cabon deposite...reduce the friction..and u should have the oil change every 3000 miles..and if u bring your own oils and oil filter..the acura dealer or any oil lube..will charge u somewhere from $20~$25.. i have been using the full syn mobil 1 for 6 years..and it is good to have them...u spend a bit more on the oil.. the engine will last longer...
Darth Tator
Originally posted by Type S:
<STRONG>the syn oil are good becuase they will stablize the engine temperature..and reduce the cabon deposite...reduce the friction..and u should have the oil change every 3000 miles..and if u bring your own oils and oil filter..the acura dealer or any oil lube..will charge u somewhere from $20~$25.. i have been using the full syn mobil 1 for 6 years..and it is good to have them...u spend a bit more on the oil.. the engine will last longer...
</STRONG>
Ambidextrous Masturbator
I think that you can change the oil a little less frequently than every 3000 miles. I usually do an oil change every 5000 miles and I use Mobil 1. I suppose it is a matter of preference based on how hard you drive your car.
Originally posted by SidVicious:
<STRONG>I think that you can change the oil a little less frequently than every 3000 miles. I usually do an oil change every 5000 miles and I use Mobil 1. I suppose it is a matter of preference based on how hard you drive your car.</STRONG>
Originally posted by russianDude:
<STRONG>
I even bet you can go up to 6-7K on synthetic without any problems</STRONG>
<STRONG>
If you plan to sell car when it hits 50K miles, its a good idea to change oil every 20K miles
<STRONG>
O yeah, I am sure that on new cars you can change synthetic oil every 20K miles and the car will work fine at least till it hits 50K miles.
</STRONG>
<STRONG>
IBankMouse
06-13-2020 12:53 PM
lanechanger
10-13-2015 10:56 AM
