Adjusting the door
Adjusting the door
Can you adjust the driver's door so it closes slighly more. The back edge of my door sticks out a small amount from the body panel and I was wondering if the latch can be adjusted just a hair. If yes, HOW????????????????
Received 1,080 Likes
you can. I believe you actually adjust the lock portion that is on the door frame, see part #21 below (far right of image). I think you just loosen the two screws on it and slide it in a little, then tighten them back up and give it a try. I remember doing something like this on my Integra.
CL-S retired 10.17.06
I totally forgot I how this has been erkin me for the last 2 yrs that the drivers door isn't flush but the passengers is on point. Gonna do this this weekend.
I fiinally got the two screws loose but there is no adjustment. There are just screw holes with no tolerance in or out. Do you to adjust them from the hinges on the front of the door. That seems to be the only info I can get off net. That seems to be over my head mechanically. Any help?
soupi
14
11-15-2015 11:15 AM
