Acura Stamped Calipers
question: i have a 2003 CL-S. looking to change out my OEM Calipers for the RL Calipers. has anyone done this before for the CL-S? are there any other Acura Factory Stamped Calipers that i can use for my application?
please help..
please help..
Whats up with RDX owners?
You'll need to fab up an adapter plate and then get new discs, and have them redrilled to the correct lug pattern.
Legend calipers work, but they dont say Acura on the side of them.
the RL has a 5x100 lug pattern where our cars have a 5x114.5 lug pattern. but why would he have to get new rotors? he cant use CL rotors?
NSX calipers work too, but they have NSX written on the side.
if i had to custom fab up some brackets, then i would use these instead:
same bolt pattern too. I can get them for 600 easily.
Arent the RL rotors 12.6" whereas the CL rotors are 11.1". Kind of overkill just upgrading the caliper and not the useable surface of the discs.
naw, i knew i had to upgrade the rotors as well. dont ask me what the specs are..i left them at the office this morning. i just really like these calipers, and thus far i havent seen it done. as us CL-S owners know, the parts for this car are scares, so i know im going to have to modify somthing. im just worried about clearance issues, bolt on issues, pressure issues. (etc etc). aznboi2424, those are some really nice calipers, but kind of steep for me. do you mind telling me were you got those from? my boy was just telling me to paint my current calipers and just get the Acura stickers and paste them on, however im not feeling that.
6speed
Goto the fastbrakes website and talk to an associate there. I have been talking to an associate there for a few weeks now and this is a reply that I got.
"The problem with the RL calipers on the 5 bolt cars is the rotor offset is greater then it is on the Integra/Civic.
Because of this greater offset, the bolt holes that the caliper uses to mount to the bracket would not have enough material to adequately secure the caliper.
There are a couple of ways to proceed; first would be to use a different rotor, keeping the bracket the way it is, or change the offset as much as possible and reduce the thickness of the outside brake pad.
We have looked for a different 1 piece rotor but have not yet been able to find one that would work. If we can’t find one that only leaves using a 2 piece rotor, which would increase the price by at least $450.
Changing the bracket offset to work with the thinner pads is relatively simple, although doing that isn’t really the way we like to sell kits. I’ll know more on if this method will work shortly; a customer is trying it now."
I was hoping to find a way to put these RL calipers on since I havent seen any CL's with them yet. For the price of RL calipers and the mounting kit it will be just as much if not more than going for a Wilwood Big Brake kit.
I'm still trying to get this to work though since it will be unique.
6speed
also a quick note..if you do happen to proceed with putting RL calipers on you need to take into account the change in the braking bias and possibly changing the master cylinder. just cause the caliper is bigger doesnt mean you will stop faster.
Whoa!! Very imformative! I really appreciate all your guy's time in this matter. jl03Cls, can I ask you to follow up with us on what the outcome is with your contact at Fastbreakes? As your contact there said, this has never been done before and i think if it can be done, this would really be big for us in mods for our cars. Finding parts for the CL-S is like finding Noahs Ark.
6speed
-Jasen
6speed
i think it could be available parts for the cl provided fastbrakes gets the mounting issue resolved. either smaller thinner brake pads or thinner/1 piece rotor would most likely make it work. Then its just an issue of buying RL calipers. used isnt too bad but brand new and youre looking at $800 just for the calipers. plus you should probably look into upgrading the rear brakes if the RL calipers are used. The wilwood BBK is $750. In my opinion its cheaper to go with a BBK....but more unique if RL calipers are used.
Ultra Negro
Well you can do like i did, search around for NSX calipers found some here
http://www.rockauto.com/catalog/rafr...c1000887k22688
cost me 207 not sure what shipping was but its less than 3 hundred, i just basically bought the caliper, and you dont have to change the master cylinder
direct bolt up too btw.
3.7L Nitrous Breathing CL
I believe the NSX calipers are 4 piston, so you will have more bite. Its very similar to the Legend caliper swap.
6speed
^ i think what he is saying is since there is 2 pistons it has a more "spread out" placement of pressure as opposed to the the 1 piston on the cl calipers. thats the only reason i can see
but then again i guess a better way to say it is that it prolongs the rotors life. it will eventually warp im sure.
The rotors will warp from heat. Not where the pressure is being applied. The surface of the rotor needs to be larger to dissapate heat better. A larger caliper isnt going to decrease warping. It will provide better stopping power, but over time excessive heat will warp the rotors.
Ultra Negro
1991-1996, 1997 and up have slightly large calipers as well as rotors and will require the necessary mounting hardware to make them fit, ive already put them on my friends CL, just need to do mine, btw you have to swap what sides they go on as well so that the drain plug is near the bottom, so basically left is right and right is left.
97 and up require some fab work.
Right?
handsom-hustla
11-13-2015 05:04 PM
merc009
10-03-2015 12:59 AM
nuldabz
09-03-2015 05:49 PM
