Accelerator pedal sticking...
Old Feb 25, 2004 | 10:27 PM
iceberg117's Avatar
Hi,
I purchased my 2001 cls last month and I have noticed that the accelerator pedal sticks sometimes especially in the morning when it has been sitting over night.
I am very familiar with engines, so I suspect that there is some carbon build up inside the throttle body where the butterfly wings open and close. I could probably take care of this problem myself, but I would rather have acura do it. Is this covered under warranty. I purchased my car certified, with a 1 year (12,000 mile) bumper to bumper warranty.
Thanks for your time...Kevin
Old Feb 25, 2004 | 10:36 PM
Guru's Avatar
AKA MaxGeek
Yup it should be covered under warranty
Old Feb 25, 2004 | 10:47 PM
BoostedM3's Avatar
Bagged hybrid
Could be a couple things as I had this problem. They will most likely try to oil up your throttle cable saying that it's dry, but tell them to check the tb itself. I had mine replaced 3 times b/c it had warped.
Old Feb 26, 2004 | 12:04 AM
Dan's Avatar
Dan
Confused
Mine was done under warranty at 24,000 miles.
Dan
Old Feb 26, 2004 | 07:47 AM
DelawareCLS's Avatar
Along the same lines, mine only sticks when starting up from a standstill in 1st gear (I have a 6 speed), but is fine in all other gears. If I tap the gas prior to letting the clutch out, it's fine. Would this be related to the throttle body as well, or something different?
Old Feb 26, 2004 | 03:53 PM
Dan's Avatar
Dan
Confused
Same problem. Get it fixed.
Dan
Old Feb 26, 2004 | 04:03 PM
anothercls's Avatar
Mine did this on a couple really cold mornings after sitting for 48hrs, since then no problems, maybe I will add it to the list for the next dealer trip.
Old Feb 27, 2004 | 04:07 PM
Chemmech's Avatar
I had a similar problem. I fixed it by lubing up the pivot points on the accelerator pedal.
Old Feb 28, 2004 | 11:41 AM
lead_sled_dog's Avatar
Back to Four Doors
Re: Accelerator pedal sticking...
Originally posted by iceberg117
Hi,
I have experienced the same problem from day 1 with my CLS. About every 6 months (10,000 miles or so), the throttle will stick when cold. I take it to the dealer and they spray throttle body cleaner into the intake and the problem goes away. If I weren't so lazy, I'd buy a can of the stuff and do it myself.
Good luck.
Mike734
Dec 10, 2021 01:25 PM
SidhuSaaB
May 30, 2020 12:40 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
knight rider
Mar 4, 2016 08:59 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
