Accelerator pedal sticking...
Hi,
I purchased my 2001 cls last month and I have noticed that the accelerator pedal sticks sometimes especially in the morning when it has been sitting over night.
I am very familiar with engines, so I suspect that there is some carbon build up inside the throttle body where the butterfly wings open and close. I could probably take care of this problem myself, but I would rather have acura do it. Is this covered under warranty. I purchased my car certified, with a 1 year (12,000 mile) bumper to bumper warranty.
Thanks for your time...Kevin
Bagged hybrid
Could be a couple things as I had this problem. They will most likely try to oil up your throttle cable saying that it's dry, but tell them to check the tb itself. I had mine replaced 3 times b/c it had warped.
Along the same lines, mine only sticks when starting up from a standstill in 1st gear (I have a 6 speed), but is fine in all other gears. If I tap the gas prior to letting the clutch out, it's fine. Would this be related to the throttle body as well, or something different?
Dan
Back to Four Doors
Re: Accelerator pedal sticking...
Originally posted by iceberg117
Hi,
Hi,
Good luck.
SidhuSaaB
05-30-2020 12:40 AM
