About to do a coolant flush - any other related maintenance?
Old Jul 25, 2012 | 01:20 PM
01RedCLS's Avatar
I'm finally getting around to performing a coolant flush on my '01 CL-S (130k miles) since my last one was about 60k miles ago.
I searched and found the general procedure, so my main question is "related" maintenance to do when performing a coolant flush.
  • Replace thermostat?
  • Replace any hoses known to fail, etc for this car?
  • Replace any related sensors?
Reason I ask is that I also own a Ford Focus and the thermostat housing is a very weak (plastic) link on the car and should be replaced every 30-40k miles.
Oh and can someone confirm how much coolant to use for the flush? I just read our capacity is 1.48 gallons, is that the case?
Thanks!
Old Jul 26, 2012 | 11:56 AM
civicdrivr's Avatar
I believe it is about 1.5gallons. You might as well replace the t-stat and the rad cap. If the hoses are hard, replace them. You shouldnt need to replace sensors.
Old Jul 26, 2012 | 12:11 PM
FwC's Avatar
FwC
Everytime i do a coolant flush, i use a prestone coolant flush. Basically drain it. Put in coolant flush. Run for a few days or 500 miles. But i dont think its a good idea midsummer if the temps are over 100 daily like here in phx. Then drain it and flush it with hose water. Then it wouldnt be a bad idea to replace hoses, thermostat and rad cap if its bad. I usually make my own prestone mixture from concentrate and distilled water 50/50. If this is new to you, just remember to be cautious when removing anything like hoses and caps from anything under thermal pressure. and let the engine cycle to standard temp and refill radiator a few times to ensure you refill the coolant in the block and burp air.
Old Jul 29, 2012 | 10:42 PM
holeshot_04's Avatar
you use Preston anti freeze? Honda/Acura Type 2 pre-mixed is what should be used. The Blue stuff, not green, or yellow.
Old Jul 30, 2012 | 01:31 AM
FwC's Avatar
FwC
Yea, prestone works fine for me. I've pretty much gone "green" with my antifreeze. It's just easier and works perfectly fine, but I made sure to flush out all the old stuff before using it in my car permanently.
Old Jul 30, 2012 | 08:35 AM
01RedCLS's Avatar
I plan on using Peak 50/50 - it's yellow. I'm not sure why I would *have* to use the Honda product?
Old Jul 30, 2012 | 11:44 AM
civicdrivr's Avatar
I've been using Prestone for a long time.
Old Jul 30, 2012 | 01:13 PM
fuzzy02CLS's Avatar
Prestone is fine in this car. The other ones last longer supposedly. The newer cars you have to watch as they take other coolant that's orange.
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
LeVeL
Oct 18, 2015 04:19 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
