6Speed Shifting Issue
I just bought my 6 speed manual CL-S, and while I know the transmission problem seems to be limited to the autos, has any one had a major problem with the manual?
The only thing I am seeing, is that the clutch fails to engage smoothly. This makes every shift feel like a clutch burn, or the opposite, where it almost stalls and instead lurches the car forward. It's annoying.
Is this just the result of the abnormally long clutch pedal that Honda likes to use, or is it just me? I've been driving manuals for 14 years, and have never had a consistent problem like this.
Thanks!
Dan
Thanks!
Dan
fails to engage smoothly???
the clutch burn i assume you are referring to the fact that the rpms tend to drop slowly....and when shifting fast you almost drag the engine speed down a little as the clutch engages (assuming you dont wait for it to drop on its own)
the clutch is not linear, it grabs quickly at high positions and little before that...
You will get a custom to the clutch soon enough
I felt the sameway when I got mine, the clutch feels as if its engaged or not no inbetween, but I have found that it works well in quick acclerationsl, just not for smoothly crusin around
There was one member (Jake, I think) that had his clutch replaced very early and when they tore it apart it was quite abused and worn. I think that his car was bought slightly used (under 1K miles) and the thought was that the previous drivers abused it. Someone else had oil leaking onto their clutch assembly which caused some burning, but was easily fixed.
My clutch engagement has been smooth and consistent since day one. It engages close to the floor (about 1.5 - 2") in the early part of pedal travel. I did have to get used to this clutch, like one would with any, but that didn't take too long.
Mines the same way. It took a while for me to get 2nd gear smooth. I find the car shifts alot better when you shift fast, & at higher RPM's. I also found if I'm just crusing shifting slow, I leave the clutch down though the whole shift, & then slowly release it, it becomes very smooth.
It took me about 3 weeks to get used to the clutch. There's nothing like shifting into each gear and feeling the precise 'click' as the gears engage.
I wouldn't go ever back to automatics transmissions- even in sucky LA traffic!
At nearly 12grand on the odo, I am going to tell you opposite of what I have said in many many previous posts:
THE TRANSMISSION IS NOW SMOOOOOOOTH.....probably cause of the warm weather..it seems to really dig warm weather...butter smooth..from 1st to 2nd to 3rd and 4th..all very smooth..notchy feel is there only when the car is completely cold...warmed up and it's butter smooth...
I'm no longer bitchin' about that...it's wonderful now
The clutch is normal as usual...1.5" engagement from the floor...smooooooth as butter baby!
Oh yea..absolutely NO RATTLES NOW....well, except for that sunshade thing...but I keep it closed anyway...
The clutch is normal as usual...1.5" engagement from the floor...smooooooth as butter baby!Oh yea..absolutely NO RATTLES NOW....well, except for that sunshade thing...but I keep it closed anyway...
Originally posted by Syncros-CL6
my clutch engages fully a lot higher than the 1-2 inches from the floor....
mine engages pretty high.
? Maybe you should take it in to see if you're up to spec.
Thanks guys, it sounds pretty normal. I agree with those who said that this car is geared for quick acceleration, because if I am letting her fly, the clutch is perfect. But when I'm driving my girlfriend around, it's a little clumsy feeling.
I guess "it's all in the hips...it's all in the hips..." Just need to ease the tension.
OK. I got a PM about my clutch engagement. I've always thought that it engages (or technically, disengages, depends how you look at it) about 2" off the floor. It seems that I'm wrong, or at least the Helm says so. Sorry.
From the Helm on clutch pedal specs:
and that fish I caught was this long
- Clutch Pedal Stroke 142.5-152.5mm/5.6 - 6"
- Clutch Pedal Free Play 10-18mm/0.39-0.71"
- Clutch Pedal Height 190mm/7.48"
- Clutch Pedal Disengagement Height 79mm/3.11"
