Is this 6spd the same
Old Apr 5, 2006 | 07:54 PM
00suprchrgdAV6's Avatar
Just wondering if the 05 tl 6spd w/ overdrive is the same as the 03 cl 6 spd. Trying to do a swap.
Old Apr 5, 2006 | 09:01 PM
blk2001tlon19s's Avatar
318whp/289wtq @ 6psi
I don't believe so.
2003 Cl-S 6 speed transmission part#20011-PYZ-C61
2005 TL 6 speed transmission Part#20011-RDE-C62
I got the part #'s off www.acuraparts247.com
Old Apr 5, 2006 | 09:07 PM
GreenMonster's Avatar
Old Apr 5, 2006 | 09:10 PM
mrsteve's Avatar
Only the flywheel is different between the two. Theoretically it should bolt up just fine.
Old Apr 5, 2006 | 09:25 PM
Zippee's Avatar
Are the gear ratios the same?
Old Apr 5, 2006 | 09:33 PM
Even if it bolts right up will all the wiring be the same as the regular 6 spd swap?
Old Apr 5, 2006 | 09:38 PM
mrsteve's Avatar
Identical
Old Apr 5, 2006 | 09:39 PM
mrsteve's Avatar
I'm not sure but I don't know why it wouldn't. The J32 block is the same as far as I know.
tonio
Feb 5, 2019 05:43 PM
BoricuaTL
Apr 8, 2016 01:08 PM
jimmyfu
Aug 30, 2015 08:05 PM
jipper
Oct 1, 2006 09:36 PM
KXM
Aug 26, 2005 09:19 PM
