6MT tranny problem
Old May 29, 2004 | 07:48 AM
civic4982's Avatar
SHIFT_over.so.I.can.see
6MT tranny problem
anyone know why a 6MT tranny might not be able to shift to the "lower" gears? "lower" meaning 2nd, 4th, 6th, and reverse. It shifts into 1, 3, 5 fine and drives fine in those gears. engine sounds perfect when driven in 1, 3, 5.
Car had a minor accident at about 15 MPH.
Any tranny experts around here that may be able to give me some blind advice or a set of issues that may be present here to cause this?
I'm thinking maybe the cable is caught on something for the tranny. I pull down and somthing seems to be keeping me out of those gears and I don't know what. The damage to the car is on the front driver's side corner.
Old May 29, 2004 | 07:49 AM
civic4982's Avatar
o yeah, and I can partially get it in reverse, or enough so that my passenger side side-mirror tilts down b/c it feels the gear is in reverse but it won't go all the way in the 2, 4, 6, and reverse gears.
Old May 29, 2004 | 07:54 AM
rezurex's Avatar
drop em like its hot
wow. there goes my assumption only auto trannies from acura blow! jeezus.
hope u have better luck than i did with my auto tranny. 3 replacements and counting at 45k...
Old May 29, 2004 | 08:06 AM
brian6speed's Avatar
Lone Wolf
why are some people just so quick to jump at oh must be another acura tranny issue. Its a manual, someones gonna have some issues.
Old May 29, 2004 | 08:09 AM
ChadT's Avatar
Spectacular Aroma About
Sounds like a linkage problem. THere is a large weight attached to the linkage at the trans on the passenger side. I would look at that to see if it may have bent upon impact. It's possible something could be caught in it too. I know the Comptech Icebox had a resonator right above there that could get caught in the linkage if it fell off when the impact occured.
Old May 29, 2004 | 09:27 AM
SiGGy's Avatar
Moderator Alumnus
He stated he was in an accident! And now he has a linkage problem
put down the talking stick!
Old May 29, 2004 | 10:03 AM
Smitty's Avatar
Sounds like a Linkage problem for sure... after you pay out of your pocket for your accident and the car looks 100%, head off to the dealership for an easy fix.
Old May 29, 2004 | 09:58 PM
civic4982's Avatar
fiured it out... the linkage got blocked b/c the battery got moved outta place due to the frame damage on the left front. lucky for me it's not damaged, soon as I get the frame straightened and the battery pulled outta the way I'll be ok. the tranny is fine says my family mechanic. thanks for the input guys. you were right on.
Old May 29, 2004 | 10:02 PM
sgmotoring's Avatar
Bleed Honda Blue
Frame DAMAGED
Old May 29, 2004 | 10:14 PM
Hobo's Avatar
Flap.
wait the frame got dammaged and no total? isnt that odd...
Old May 29, 2004 | 10:52 PM
DivinDude's Avatar
well .. let's face it .. Honda isn't known for its reliable automatic transmissions .. dating even farther back than the past 5 years ....
but in this case, I think it is a linkage issue ...
Old May 30, 2004 | 05:08 AM
SCTL-SS's Avatar
13.68 @ 102.56
I'm glad all is well-good news on the simple fix.
Old May 30, 2004 | 01:29 PM
SpeedyV6's Avatar
Old May 30, 2004 | 01:38 PM
Ant7701's Avatar
Sweet as Gold
dude...frame damage so bad to move the battery and block the trans linkage...AT 15MPH!!!!! Go back to who did the bodywork...if you take it to the dealer they will notice the damaged frame right away and then ur fawked.
Old May 30, 2004 | 05:14 PM
civic4982's Avatar
uhh... the tranny is fine... the battery just needs to be moved out of the way so it isn't blocking the linkage.
Old May 30, 2004 | 05:18 PM
Hobo's Avatar
Flap.
what was the estimate to fix it... it should be pretty hefty if the frame was bent.
Old May 31, 2004 | 01:06 AM
civic4982's Avatar
I'll find out tomorrow about the estimate. probably around 7-8K is my guess.
Old May 31, 2004 | 01:18 AM
Chopsie's Avatar
Beware of leakage
Hope all goes well.
Guess the battery is squeezed in there pretty good for you to not be able to manually move it ?
Old May 31, 2004 | 02:17 AM
mrsteve's Avatar
$7-8K out of pocket. Man I feel for ya I'm sure your insurance couldn't have been that much that you couldn't do full coverage. Hope it works out for you.
Old May 31, 2004 | 10:54 PM
civic4982's Avatar
actually it's ok... it was $5350 at the local Acura Dealership body shop. Looks like I'll be ok for repairing this car. They're also probably going to let me order my own brand new OEM parts from my distributor at my 25% discount... hooray!!!
Old Jun 1, 2004 | 10:33 PM
Chopsie's Avatar
Beware of leakage
I hope they do let you get from your distributor, and much props to that shop for letting you do so.
They say how long she'll be held up for ?
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
LoneRonin
Jan 4, 2016 01:03 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
