6MT tranny problem
SHIFT_over.so.I.can.see
6MT tranny problem
anyone know why a 6MT tranny might not be able to shift to the "lower" gears? "lower" meaning 2nd, 4th, 6th, and reverse. It shifts into 1, 3, 5 fine and drives fine in those gears. engine sounds perfect when driven in 1, 3, 5.
Car had a minor accident at about 15 MPH.
Any tranny experts around here that may be able to give me some blind advice or a set of issues that may be present here to cause this?
I'm thinking maybe the cable is caught on something for the tranny. I pull down and somthing seems to be keeping me out of those gears and I don't know what. The damage to the car is on the front driver's side corner.
o yeah, and I can partially get it in reverse, or enough so that my passenger side side-mirror tilts down b/c it feels the gear is in reverse but it won't go all the way in the 2, 4, 6, and reverse gears.
drop em like its hot
wow. there goes my assumption only auto trannies from acura blow! jeezus.
hope u have better luck than i did with my auto tranny. 3 replacements and counting at 45k...
Spectacular Aroma About
Sounds like a linkage problem. THere is a large weight attached to the linkage at the trans on the passenger side. I would look at that to see if it may have bent upon impact. It's possible something could be caught in it too. I know the Comptech Icebox had a resonator right above there that could get caught in the linkage if it fell off when the impact occured.
Moderator Alumnus
He stated he was in an accident! And now he has a linkage problem
put down the talking stick!
Sounds like a Linkage problem for sure... after you pay out of your pocket for your accident and the car looks 100%, head off to the dealership for an easy fix.
fiured it out... the linkage got blocked b/c the battery got moved outta place due to the frame damage on the left front. lucky for me it's not damaged, soon as I get the frame straightened and the battery pulled outta the way I'll be ok. the tranny is fine says my family mechanic. thanks for the input guys. you were right on.
Bleed Honda Blue
well .. let's face it .. Honda isn't known for its reliable automatic transmissions .. dating even farther back than the past 5 years ....
but in this case, I think it is a linkage issue ...
Sweet as Gold
dude...frame damage so bad to move the battery and block the trans linkage...AT 15MPH!!!!! Go back to who did the bodywork...if you take it to the dealer they will notice the damaged frame right away and then ur fawked.
Beware of leakage
I'll find out tomorrow about the estimate. probably around 7-8K is my guess.
Guess the battery is squeezed in there pretty good for you to not be able to manually move it ?
actually it's ok... it was $5350 at the local Acura Dealership body shop. Looks like I'll be ok for repairing this car. They're also probably going to let me order my own brand new OEM parts from my distributor at my 25% discount... hooray!!!
Beware of leakage
They say how long she'll be held up for ?
SidhuSaaB
05-30-2020 12:40 AM
Pham Alvan
03-16-2016 09:17 AM
