6MT-CLS - Trans fluid change need help w/ washer part #'s
I'm going to change the transmission fluid in my 6spd CL-S on Sunday. I'm going to the dealer today or tomorrow to pick up some fluid, and new washers for the following:
Drain plug
Fill Plug
Check plug
Does anyone have the part numbers handy?
I can go to the following site, but can only locate the part number for the Drain plug washer.
http://www.acuraautomotiveparts.net/...s=&view=normal
Thanks in advance
-CM
Drain plug
Fill Plug
Check plug
Thanks in advance
-CM
Well thanks for your help. Nice skate pics btw (saw the link to your angelfire site). I used to skate a while ago but wasn't really any good.
I'll change out the fluid on Sunday and will report back to how it feels. Hopefully I can determine sunday exactly what's leaking engine oil. Looks like rear main seal to me.....
I replaced my fluid with the GM synchomesh a few months ago. It's a bit smoother, but I still have 2nd gear notchiness before it's warmed up. I think that most other members that have done the switch have had better improvements than me.
Hope it works for you.
I have the exact same issue w/ 2nd gear. Its really bad when its cold out, sometimes even having a slight synchro grind. After a few miles of driving it clears up pretty well.
Yes, I used the GM Syncromesh with friction modifier, but I didn't even know that there was another kind.
You're right - it sounds like our cars have the same issue: only 2nd gear, but once it warms up, it's all good.
Yeah the Non FM stuff is actually a generic synchromesh formula... It's identical to an AC delco product, a pennzoil product (thats 5.99 a qt from autozone) etc. The FM product is expensive as hell, i just bought 3 qts for like 44 bucks.
Try this: https://acurazine.com/forums/showthread.php?t=716428 and change out the shifter bushings for aluminum from Corsports...like buttah baby.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
If I were to do only one mod it would be the Corsports bushings - significant improvement in smoother movement and precise feel w/ engaging the gears.
mada51589
05-03-2022 08:54 PM
jamestheunderdog
07-19-2016 07:58 PM
nanos
11-12-2015 08:41 PM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
