626 Header Install Help
Old Apr 26, 2007 | 03:24 AM
LIPPSTUH's Avatar
Unregistered user
I'm going to get my XS headers tomorrow and want to install it saturday. Anyone want to lend a hand? if you have air tools, even better . i hope i can pull this off...
Old Apr 26, 2007 | 10:12 AM
Kulrevon's Avatar
where are you getting the headers from and how much?
Old Apr 26, 2007 | 11:28 AM
mrsteve's Avatar
Search!
The thread RIGHT below this one has all the information.
https://acurazine.com/forums/audio-video-electronics-navigation-22/how-do-u-install-line-out-bypassing-stock-eq-188313/
Old Apr 26, 2007 | 02:03 PM
NEVERSUMMER's Avatar
EVERYTHING IS FOR SALE!
I did mine in about 2 hours. Just a tip if you have to do it yourself.
1: Take left fan behind the radiator off before front un-install and install.
2: Install the rear header from underneath the car.
Your all set.
Old Apr 26, 2007 | 05:07 PM
LIPPSTUH's Avatar
Unregistered user
thanks, everyone is giving me that sarcastic "good luck" kinda putting me down. it shouldn't be that hard right?
Old Apr 26, 2007 | 05:14 PM
ironsurfer129's Avatar
CL-Pride
I don't think it is that hard. It will definitely take more time than, but you will get it. I think the hard part might be getting room to apply force. Like Neversummer said, take off fans here and parts there should get the job done easier. ALSO remember where all the bolts and screw go. I always ended up with extra bolt and such.
Old Apr 26, 2007 | 05:29 PM
subtledreamer's Avatar
woooo!!
I've done them on my CL-S before. It took us a LONG time because of how the bolts are. As long as the bolts can be easily removed (i.e. liquid wrench, etc.) the install is pretty straightforward and easy. Me and Jon might be able to come over and help in the afternoon. What tools do you have?
Old Apr 26, 2007 | 05:30 PM
kensukikatayo's Avatar
Turbo + Sound = Hey-pee
Old Apr 26, 2007 | 05:32 PM
LIPPSTUH's Avatar
Unregistered user
tools, um very short wrenches (uses bits). i just got a pretty large torque wrench. screw drivers... which aren't needed.. no air tools =[
not sure what a liquid wrench is, i'm still trying to find a 2 foot long wrench. help would be great, i have to research on what other parts i might need: gaskets, gotta buy screws.
Old Apr 26, 2007 | 05:47 PM
Check for the bolt pattern. I think it was M10 x 1.25? Don't quote me on that though. Try searching. Get the nuts to go along with them. We'll bring our tool sets too.
Do you have jack stands and a jack? The higher the jack goes the better. Get some gloves too and DON'T drive your car for at least an hour before we start or else we're gonna burn up in the heat.
Old Apr 26, 2007 | 06:40 PM
LIPPSTUH's Avatar
Unregistered user
i have a cheap ass jack, no jack stand. works just as good. i'll go pick up some bolts soon and order the compression gaskets from a 91 NSX
Old Apr 26, 2007 | 06:42 PM
maying2001's Avatar
What's VTEC?
^^If u want me and my friend can help u.
Old Apr 26, 2007 | 07:11 PM
g1underground's Avatar
Cosmic Cowboy
Sorry I have to respond to this.........please do some research on the necessary tools you need, and buy quality tools. Craftsmans are among the best affordable tools. And please no cheap jacks or jack stands, your life isn't worth the install. The right tools makes a major difference.
Old Apr 26, 2007 | 07:45 PM
LIPPSTUH's Avatar
Unregistered user
thanks for the response, but the jack is not mine, its a friend's. and all my tools are pretty good quality, craftmen, Milwaukee, etc
Old Apr 26, 2007 | 07:49 PM
asianspec's Avatar
read our thread from the 1st gens
https://acurazine.com/forums/showthread.php?t=187885
Old Apr 26, 2007 | 11:01 PM
We'll bring some jackstands too then and extra torque wrenches just in case. I don't know what they're called, but if you can get those jointed extensions (3/8" drive) those help too for some of the nuts on the headers, esp for the rear.
Old Apr 26, 2007 | 11:14 PM
LIPPSTUH's Avatar
Unregistered user
i think i know what you're talking about... is it a bent bit? i can probably get them at harbor frieght (best store ever)
Old Apr 27, 2007 | 12:22 AM
It's not really bent but its on a joint?
BTW: MSG me on AIM, makes it easier: k2WorldZk
Old Apr 27, 2007 | 08:13 PM
ll1l2l1l2lll's Avatar
w202 on carlssons
i have two of the stand you could drive up onto.. i know that'll make life a lot easier and safer when you actually get under the car. PM me if you need those.
Old Apr 27, 2007 | 09:34 PM
BigLizard's Avatar
Moderator Alumnus
The drive up stands are very helpful for doing anything underneath the car. Even though I'm dropped, I was still able to change out the sways, LSB, and headers.
Old Apr 28, 2007 | 01:30 AM
Chuco's Avatar
Help with your Header install
Read this link found in the community.
https://acurazine.com/forums/showthread.php?t=186749
Read my post under 'chuco'
Old Apr 29, 2007 | 02:30 AM
LIPPSTUH's Avatar
Unregistered user
got them installed!
thanks kenny + jon + that one guy for the help... very nice people! can't believe they did such a good job. real quick install, no problems except we broke a bolt used in the install of the header to downpipe. replaced it.
couple of questions though:
we had to use a set washer + nut from xs... only one set, but the bolt is grade 8 i believe. is that a problem?
when i rev, there's no problem. but when i put it in gear and drive i hear this hissing noise. most apparent from 2-3k RPM, but after that i don't hear it (as much) probably b/c the engine gets louder.
i haven't had a chance to really test it.
Old Apr 29, 2007 | 04:32 AM
got them installed!
Could potentially be an exhaust leak or it could be resonance?
Smoothest header install I've ever witnessed! 03 No rusted bolts! Did encounter some weird problems during the install though (i.e. one of the bolts for the headers came out with the nut!!)
It's a pleasure to help a fellow forum member. Enjoy em!
Old Apr 29, 2007 | 08:43 PM
mrsteve's Avatar
There's going to be an increase in exhaust noise because the headers are a much thinner metal than OEM.
Old Apr 29, 2007 | 10:03 PM
LIPPSTUH's Avatar
Unregistered user
i like the tone of the exhaust, not bad for stock exhaust =]
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
CLsuperhero
Sep 23, 2015 12:53 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
TxRzrBk
Sep 17, 2015 01:07 PM
