60k service at Pohanka?
pumpkin escobar
Hello,
Just curious to see if anyone here has had their 60k mile service done at Pohanka Acura in Chantilly, VA?
If so, how was the experience? They said they charge $350 for the 60k service. I think that is kinda steep.
I was looking over the manual and the 60k service is basically changing oil and rotating tires and checking this/that.
Are they supposed to change/flush the tranny fluid and coolant too? What about brake fluid?
Please advise.
Thanks.
Please advise.
Thanks.
pumpkin escobar
Originally Posted by chabanais
You should be a member of, or join, Owner Link. This will tell you. Didn't you get a Maintainence Journal with your car?
Yes I am a member and yes I got the maintenance journal. It does NOT say anything about tranny fluid change or coolant flush for 60k service.
Thats why I am asking those ppl who have gotten their 60k service done at Pohanka if their service included the tranny and coolant flush.
pumpkin escobar
Originally Posted by 03 CLS
Not 60k, I'm due for the 30k soon and I'm scared to find out what that is going to cost.
Ok, the replies I have received so far do NOT answer my question.
C'mon guys, I know atleast a few of you have gotten the 60k mile service done to your vehicles.
Anyone here got it done at Pohanka in chantilly, va?
Did they flush your tranny and/or coolant?
How would you rate their service?
I see alot of CL's on the road.
Liquid Ice
No offense, but why don't you just call Pohanka and ask the service people what they do at the 60k service? Then at least you'll know if they change the tranny fluid or not.
I've gotten all of my service including mod installs done at Pohanka and they've always taken care of me. Jerry Soriano is the guy you wanna talk to, he's a good guy .. mod friendly and won't screw you.
I've never gotten my 60k service done at Pohanka though, sorry. So like I said, call them and find out whats involved.
http://www.pohankaacura.com is their website if you need to get their phone number.
BTW- Just for reference, there are 3 different 60k service types:
1. 60,000 mi/96,000 km/4 yrs Scheduled Maintenance (Severe)
-Replace timing belt, and inspect water pump. (See timing belt on page 260 of your owner's manual for replacement information under special driving conditions)
-Replace engine oil and filter.
-Inspect front and rear brakes.
-Rotate tires (follow pattern on page 264 of your owner's manual.
-Inspect tie rod ends, steering gear box and boots.
-Inspect suspension components.
-Inspect driveshaft boots.
-Check parking brake adjustment.
-Lubricate all hinges, locks and latches with multipurpose grease.
-Inspect brake hoses and lines (including ABS).
-Check all fluid levels, condition of fluids, and check for leaks.
-Inspect cooling system hoses and connections.
-#Inspect exhaust system.
-#Inspect fuel lines and connections.
-Check all lights.
-Inspect the underbody.
# = See information on maintenance and emissions warranty, last column, page 223 of your owner's manual.
-Replace air cleaner element.
-Inspect and adjust drive belts.
-Replace dust and pollen filter (See dust and pollen filter on page 259 of your owner's manual for replacement information under special driving conditions).
2. 60,000 mi/96,000 km/4 yrs Scheduled Maintenance (Normal)
-Check all lights.
3. 60,000 mi/96,000 km/3 yrs Scheduled Maintenance (Severe)
-Replace transmission fluid.
Check OwnerLink if you need more information. (http://www.ahm-ownerlink.com)
If the cost is to replace the timing belt along with the rest of the stuff listed, then the price is pretty good.
-Check all lights.
-Check all lights.
sort of off topic but i'm getting my 52.5k service done at Chevy Chase Acura next week, sounds like they just change the oil, rotate the tires and check the brakes. I forgot the cost.
COME AT ME BRO!
there is no 50k check up on our cars its every 60k then 120k the change oil, and flush the engine and trans 350 is a fair price its about the same as if you took it some where else.. deal with jerry as your service write.. he is the best at pohanka
I just do whatever is necessary to keep the warranty in effect. Oil and filter every 4-5000 miles--trany fluid change every couple of years--brake and coolant fluid every 3 years. Get a inspection of the underbody of the car every 1-2 years which cost about 50.00 to check brakes and boots. The rest is unnecessary unless you can see a problem.
pumpkin escobar
i just called pohanka and spoke w/ jerry. its gonna run $380. tranny fluid, oil change, air filters, check this , check that. but does not include coolant flush. it is an xtra $60. is that a good deal?
COME AT ME BRO!
call around you can get the same thing done at jiffy lube( i used to work there) you might find some place cheaper. but it should all run about the same rate so i would go with acura. i just drop my car off at pohanka for safty, emmis, oil change, slotted crossdrilled rotors installed and my gauages installed
Try Karen Radley Acura in Woodbridge...ask for Pam. I bought my car at Pohanka but don't trust them with the service (the service reps are big on attitude and not good at customer service). Karen Radley also has service coupons on their website and their prices tend to be a lot lower than other dealers in the area, in general. It may be out of the way but the techs there actually care about working on your car.
COME AT ME BRO!
pumpkin escobar
ok, so i took my car to pohanka acura in chantilly....delt w/ jerry soriano...great guy...i recommend going to him if you need service on your acura....all in all, very good experience..tehy ran out of loaners, but they put me in a pontiac grand am gt for the day...
52.5K is the 6th time for this service (the other one should have been the 30K major service).
cool, i have an appointment for tomorrow.
https://www.ahm-ownerlink.com/login.asp?brand=acura
I just noticed that there's a Acura Dealer 7.5 miles from my house now
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
Got a Job!
I just called the dealer today to get my oil changed on Thursday...and they mentioned I haven't gotten m 60k done yet (I'm at like 63.4k). Anyways, I asked how much it was and he said $299, however this was at Keyes Acura in Van Nuys, CA. Just wanted to let you know. So yeah, is this shit necessary? I dont wanna waste 3 bills on this BS if I don't need to
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
COME AT ME BRO!
Honda should sell it!
happened with me over there.
pumpkin escobar
Originally Posted by dark knight
too bad jerry doesn't rub off on the rest of them,i'm never going back there after what just
sent email. I had a 10am service and I arrived at 10:15(traffic), so I waited 15 min during
which 2 people told me somebody will be right with you. meanwhile a guy in a new TL-A
Spec who went in just ahead of me got helped right away.When a consultant came over
to assist me ,i explain I had an appt and I want the 37.5k service. First, he tells me it will
be a few hours and asks if I will wait,I say "Yes", then he tells they may not get to it until this evening and I respond "so at the latest this evening"; "no more likely TOMMOROW
MORINING AT THIS TIME" he tells me and adds "we will pay for car rental, but it won't be
an acura". I told him I'll pass and left. He gave no other options like would you want to
reschedule for another time. This is the 2nd consecutive incident with them, the first my
card was rejected and I had to borrow money from a friend to pay for the 30kservice
after which the cashier told me the machine wasn't working properly. Granted,they
were all very busy and i understand it would take a few hours but a whole day?
jterp7
3G MDX (2014-2020)
02-03-2016 08:34 PM
