3rd brake light won't STFU
Old 04-09-2012 | 04:29 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
so for the past few days my car has been making this GOD awful squeaky noise right from what appeared to be the 3rd brake light. so i took out the rear seats, console, back seats and the piece covering around the 3rd brake light. removed the 3rd brake light to find the culprit is a broken tab!!! all that annoyance cause of a stupid 1 mm tab...i drove the car each time i removed anything from the back and once the 3rd brake light was removed there was no sound. which is how knew it was the 3rd brake light was
SO.. if u got a PITA creak/squeak coming from the back center of ur CL.. odds are its the 3rd brake light.
the reason it's so likely to squeak is cause it is 2-3 pieces all clipped together and if everything isn't perfect it will shift as u hit bumps and then the plastic makes the worst sound imaginable... i wanted to shoot my car the last 5 days... thankfully i can holster that
hope this helps
Oakroadsteve (04-10-2012)
Old 04-09-2012 | 04:49 PM
Edit: Merged
Old 04-10-2012 | 10:04 PM
Beavisboots's Avatar
CL-S 6Speed is rarely in
On the topic of annoying squeaking....
I have one that took me some time to trace. Turns out the body shop that replaced the passenger airbag never put the nuts on the three studs that hold the airbag down.
Old 04-10-2012 | 10:14 PM
there's nothing worse than a frigging rattle.. it's such a small problem technically but it really fucks up the driving experience. and music can only be played so loud, so often
Old 04-12-2012 | 02:47 PM
aznboi2424's Avatar
That would have not been fun if that thing went off in an accident.
Old 04-12-2012 | 08:05 PM
civicdrivr's Avatar
Whats up with RDX owners?
I agree that rattles are annoying. I find this to be the best way to fixing them:
MD03CL-S (04-15-2012)
Old 04-12-2012 | 09:38 PM
LOL but some ppl like silence. i only listen to music in my car i.e it's not a big part of my life.
Driving with no rattles and just the subtle rumble of the motor is much more pleasing in many cases.
Old 04-12-2012 | 10:34 PM
civicdrivr's Avatar
I know what you mean. Most times the rumble from the exhaust is enough.
My sunroof, dash, and rear deck rattle. I have no energy to fix them all. When it warms up, the rattles lessen, so I just hope for warm weather.
Old 04-12-2012 | 10:49 PM
i consider myself lucky then
Old 04-14-2012 | 08:13 AM
eneffex's Avatar
I have this problem with my spoiler 3rd brake light, I think i've seen a "great stuff" fix by someone on a 2g tl, where in they just filled the hollow spoiler with it lol I might have to give that a try, dynomat hasn't done the job.
Old 04-14-2012 | 10:35 AM
i also just took apart my armrest to find the reason it was wobbling all over the place was because of 2 loose bolts holding the track to the guiding mechanism !!! tightened them up good and now it's got about 1/3rd the play it had. I KNOW a lot of you CLers have the same damn problem cause mine had been like this since i got the car!!! thought it was normal until today when i went to install a new armrest cover and found the culprit!!!!
hopefully this help some of u folks out..!!!
Old 04-14-2012 | 05:02 PM
civicdrivr's Avatar
I had the same problem when I first bought the car.
Old 04-14-2012 | 07:06 PM
arm rest looks amazing by the way.. its like a couch is under my elbow
mada51589
05-03-2022 08:54 PM
wusty23jd
09-24-2015 11:41 AM
Nicho863
09-02-2015 08:12 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: 3rd brake light won't STFU
