254hp and 284lbs torque ( with 125 shot and major fuel problems)
fastest time 13.4@107 !!!
well i decided to dyno my car last friday, before i went to test and tune at rockingham friday night.... i made 4 pulls on the dyno and my car is still runing way to lean. i have ordered injectors for my car 2 times before but both times it took to long so i just cancelled my order....
my best run was
254hp AND 284lbs torque
after the dyno results i decided not to run the car because it was so lean... i'm going to try a couple more things, but i might just have to brake down and get the zex wet kit ...
as soon as i can get my dyno sheet on my computer and get it hosted i'll post it up asap....
my best run was
how is it that the TQ is so high?
would you think my car is producing more TQ than HP when i'm spraying?
Originally posted by pimpscls
omg why is the tq higher then the hp, and those are some impressive numbers
Adventurist.
Power (hp) = Torque (ft-lb) * RPM / 5252
Power (hp) = Force (lb) * Velocity (MPH) / 374
Easily understood, HP and TQ will always meet at 5252 (give or take due to tolerances in calibration of machinery). Increase the curve in another you increase the other conversely.
This of course is for gasoline engines. Ever see a tuned TDI engine? 200hp with 500lbs/tq is 'amazing'!!!
thanks guys
nitrous normally gives you more torque than HP... i have the zex dry kit (for the people that didn't know)... i'll just have to wait and get some bigger injectors, if that doesn't work i'll be switching over to a dry system..
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
Originally posted by bryanz3.0cl
its definately time to go with a direct port.
Originally posted by fastvtecCL
thanks guys
thanks guys
fuck the injectors, just go DP or atleast wet. You should never go dry above 100
shut up
BoricuaTL
04-08-2016 01:08 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
