2003 CLS6 Accelerating
Old Jan 24, 2022 | 03:21 PM
TylerMeekins's Avatar
6th Gear
Hello, new member! I hope this is the right place to have this conversation. I have a 2003 CLS6. I recently noticed that after snowing several inches here in VA I thought maybe this noise was snow under my car. Today I washed it and hit the highway for a blow dry. I noticed on the highway around 4-6 gear that car doesn't want to accelerate past 4500 rpm (in the ball park). It's almost like I'm hitting some kind of limiter. Like my VTEC isn't engaging. Car drives fine elsewhere. I am noticing a "wind suction" noise coming form front passenger side ( I thought was snow under car). Almost like my car is trying to suck in air but coming from opposite side of my air filter. Just passed inspection last week with no issues. Any help I would appreciate. Thanks!
Old Jan 24, 2022 | 04:34 PM
6th Gear
After using an OBD2 scanner... I've gotten p0219 and p1399 codes. And it seems like someone at Acura may have taken my car for a test drive last week when I went in for that state inspection.
Old Jan 25, 2022 | 10:14 AM
ttribe's Avatar
MODERATOR NOTE: Thread moved to model specific forum.
Old Jan 25, 2022 | 11:09 AM
p0219 is an 'Engine overspeed condition':
P0219 Engine Overspeed Condition (obd-codes.com)
p1399 is a 'Random Cylinder Misfire':
P1399 ACURA: Code Meaning, Causes, Symptoms, & Tech Notes (With Video) (engine-codes.com)
If the car was functioning above 4500rpm BEFORE you took it in for the Acura state inspection, perhaps the overspeed condition was the result of an overzealous technician test drive?
That is, if you can't recall an 'unintentional' overspeed rev of your own doing or a severe overrev as the result of a mistaken 'downshift', then you may have bent valves?
Bent valves happened to me, back in the day, when the faulty original factory installed timing belt tensioner caused a 'floating valve' situation, at highway speed.
Get it diagnosed / remedied ASAP.
If you go back to the same Acura dealer, be PREPARED to fight the good fight in proving your case that they are responsible, just saying.
Good Luck!
Old Jan 25, 2022 | 11:41 AM
6th Gear
Yes I had no problem pushing it to 6k rpm before taking it to dealer. I am going to take it back and see what they say.
Old Jan 25, 2022 | 12:02 PM
Hopefully, it is only a defective CKP or CMP sensor, as mentioned on the first link provided.
This would be the least expensive outcome; however, dtc's usually are present / thrown if they fail.
Old Jan 26, 2022 | 05:11 PM
6th Gear
Dropped the car off at the deanship this morning.. expecting some bad news. Not terrible but it seems my clutch, flywheel and master cylinder are all starting to die out. Has anyone had this issue before?
Old Jan 28, 2022 | 07:10 PM
FALLiiSTEENY's Avatar
get the luk kit from rock auto that's what I did
jctsxguy
2G TSX Problems & Fixes
Feb 25, 2019 04:54 PM
drewster23
Integra
Feb 21, 2010 12:06 PM
bwd22
Feb 20, 2009 07:43 PM
Modeler
Jan 12, 2004 12:05 AM
