03 key fob
03 key fob
is it possible to use the 03 key fob for a 01 cl? i wanna buy one but not sure if it is going to work, has anyone tried to use it before?
Lone Star Rider
The 01 and 03 3.2 CL use different remotes, but they are programmed the same way. Here are the instructions.
1. Turn the ignition switch to ON (II)
2. Within 4 seconds, press the "LOCK" or "UNLOCK" button on the transmitter. Make sure the transmitter is aimed at the receiver above the glovebox.
3. Within 4 seconds, turn the ignition switch to LOCK (0).
4. Repeat steps 1, 2, and 3 two more times. Use the same transmitter used in step .
5. Within 4 seconds, turn the ignition switch to ON (II).
6. Within 4 seconds, press the "LOCK" or "UNLOCK" button on the same transmitter. Make sure the power door locks cycle to confirm that the system is in programming mode. Press the "LOCK" or "UNLOCK" button again.
7. Press the "UNLOCK or"UNLOCK" button on each transmitter you want to program. Make sure the power door locks cycle after you push each transmitter button to confirm that the system aceppted the transmitter's code.
8. Turn the ignition switch to LOCK (0) to exit the programming mode.
soupi
14
11-15-2015 11:15 AM
