03 key fob
Old Nov 13, 2003 | 10:56 PM
32vv1ll's Avatar
03 key fob
is it possible to use the 03 key fob for a 01 cl? i wanna buy one but not sure if it is going to work, has anyone tried to use it before?
civic4982's Avatar
SHIFT_over.so.I.can.see
yeah... it works... just you'll have to reprogram it is all. it's pretty easy. run a search and you'll find instructions to do it I'm sure.
Old Nov 13, 2003 | 10:58 PM
32vv1ll's Avatar
does anyone know how much it cost at dealer? thanx
Old Nov 14, 2003 | 04:04 AM
fuzzy02CLS's Avatar
I hear quotes anywhere from $30-$50 for the transmitter, & more $$ if the dealer programs it. Get one off ebay for cheap, & program it yourself.
Old Nov 14, 2003 | 07:31 AM
gto2050's Avatar
Someday pigs WILL fly!
I think they are about $45. Where were you last week when I gave away 2 of them?
Old Nov 14, 2003 | 08:20 AM
SickCL's Avatar
Lone Star Rider
The 01 and 03 3.2 CL use different remotes, but they are programmed the same way. Here are the instructions.
1. Turn the ignition switch to ON (II)
2. Within 4 seconds, press the "LOCK" or "UNLOCK" button on the transmitter. Make sure the transmitter is aimed at the receiver above the glovebox.
3. Within 4 seconds, turn the ignition switch to LOCK (0).
4. Repeat steps 1, 2, and 3 two more times. Use the same transmitter used in step .
5. Within 4 seconds, turn the ignition switch to ON (II).
6. Within 4 seconds, press the "LOCK" or "UNLOCK" button on the same transmitter. Make sure the power door locks cycle to confirm that the system is in programming mode. Press the "LOCK" or "UNLOCK" button again.
7. Press the "UNLOCK or"UNLOCK" button on each transmitter you want to program. Make sure the power door locks cycle after you push each transmitter button to confirm that the system aceppted the transmitter's code.
8. Turn the ignition switch to LOCK (0) to exit the programming mode.
Old Nov 14, 2003 | 08:30 AM
32vv1ll's Avatar
thanx guys. I appriciate all the information.
Old Nov 17, 2003 | 08:52 PM
Allout's Avatar
Blown is Best
If the FCC codes on the back of the remotes matches, they should work.
datadr
Mar 23, 2016 01:39 PM
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
malvothegreat
Sep 29, 2015 12:38 AM
