03 CL Sub Upgrade
03 CL Sub Upgrade
Wasn't there a thread to upgrade the stock sub in 01-03 CL's? I can't seemed to find it now and the search function is not working for me. Help please...
As far as I know the CL doesn't ahve a factory sub...mine didn't! You can add a Infinity Basslink II for $270 total including a power kit. I just did this and it sounds great and fits in the rear corner of the trunk. Tons of space left in your trunk and you don't have to take out your headunit to install the sub. All you gotta do is run +/- wire and then tap into the rear speaker wire coming from the factory amp
Correct me if I'm wrong, I thought the the 3rd gen TL's have a stock sub, as far as the second gen tl/cl they do not have a stock sub. In terms of replacing the sound system people have replaced the stock bose amp in the tl/cl's in addition to the sound system
Yeah I was mistaken. I saw a thread on a sub upgrade for the TL. Anyway I'm sure it's been asked a thousand times but I could not find the answer. Can I upgrade the factory amp and all speakers? I want to keep the stock head unit.
yes that cool.
u usually have a STAGE 1 2 3.
= PREAMP > Mini-AMP (WHich is part of ur CD/tape player usually not powerful enuff to run subs)> AMP(which usually runn ur subs)
Or
Preamp> Mini AMP > AMP > Crossover >OUTPUT (LOws + HIGHS or even Midrange)
so in the case of the TL = cd/changer or player (Preamp + MiniAMP) > BOSE > SUB AMPS( MTX, jackhammer, sony whteva).
Or
Unless you have the hole cut out of the rear deck it would be pointless to try to add it. You could probably get more bass by upgrading your stock 6x9 to a better speaker and adding a small amp to power them.
mlody
12-04-2019 02:11 PM
InFaMouSLink
10-30-2015 09:43 AM
kb1rl
09-30-2015 10:17 AM
