03 cl-s 6 Center Console
03 Anth Type S 6 Speed
I am going to be tightening my E-Brake today. I searched and found all the information needed on doing it.
The only question I have is on the two silver panels that run the length of the center console.
How do they connect?
Are they double sided taped on?
Do they snap into place?
When is the best time to try and take them off; before or after taking the screws out?
Are they hard to get back on? Do I need to get some double sided tape?
Any info that you guys could add would be greatly appreaciated.
Excellent, I did this yesterday and my e-brake is finally working agian. Before I did this I counted like 19 clicks LOL and fully engaged it did basically nothing. Now its max at around 8ish clicks and if I pull it while driving it actually stops my car.
The console came out really easy, only a few bolts, anyone with a loose e-brake I suggest that you do this, you can also clean out all the crap that gets stuck in there.
If so, you better make sure the rear brakes aren't dragging...
The rough adjustment is back there, and you need to make sure that the brakes aren't dragging or they'll wear out prematurely. Inskip Acura messed up and had to replace the rear pads on my car
Just figured I mention it... You probably did it right, but since you only mentioned the console
Originally Posted by GreenMonster
Ahh... did you adjust it using only the fine adjustment in the console only ??
I only did the adjustment in the console, but I jacked the back of the car up so I could spin the tire. I tightened the ebrake until it put tension on the tire, then I backed it out a little bit. All in all my ebrake is actualy a brake again. and not a lever to no where. lol
Checking that the rear tire spins freely is escential... and now this info is here for future reference...
Originally Posted by LIPPSTUH
adjusting the rear brake is through the center console and not the calipers?
For some you also need to adjust at the brake on the rotor itself. I'd say try the center console first, if that doesn't do it then move to the tire.
mlody
12-04-2019 02:11 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
InFaMouSLink
10-27-2015 06:52 PM
