02 Sensor Question
02 Sensor Question
I swapped the complete 03 CL-S6 drivetrain (Engine, Tranny, ECU) into my 02 TL-P.
I've been using the O2 Sensor from my 02 TL-P for a while. I just switched over to the O2 sensor from the CL-S6, which immediately gave me a O2 sensor CEL code. (P0135)
Should I bother getting a new CL-S6 O2 sensor, or is the TL-P sensor close enough?
lowrd on tein CS biatch
Why has no one tried to upgrade to the tl 07 and up ecu? It uses both of the o2 sensors to get better fuel trims through the entire power band and is mainly why the tl had 270 hp vs our cls a year back with 252. I think the only other difference were cams... But that may be the tls motor I cannot remember.
I asked my mechanic a few yrs back and he said for the trouble it's not worth it. But if u were going to swap in another motor, I think it would be a viable way to make the car faster than it ever could be without the ecu swap. To make the switch u need the ecu, o2 sensors and wiring harness for the entire car.. More than I would do for power, but the are plenty of you on here that are more hardcore than myself so it still may appeal to many of you aziners
Now that the tl is almost a decade old I am sure one could stumble across the needed parts out of a donor for 5 bills.... In the USA lol. Not for us Canucks
cycdaniel
12-17-2019 10:58 AM
