02 acura cls engine shuts down after i start it?
Old Mar 11, 2015 | 12:27 PM
Jr_saber's Avatar
9th Gear
I just put in a new gas tank, I didn't change the fuel filter or fuel pump only a new gas tank,I drove it for 2 days.I wake up the next morning to start the car and its a long start and when it does kick over the engine shuts down in 10 sec? So I paid for a new battery,NGK' speak plugs,I checked all fuese,I check for vacuum leaks,I checked for codes and no codes,I spread Start up fluid and still dies? So I ask you this since I have a new gas tank could it be over load the fuel pump or filter because the gas deposit do have nothing to hold onto due to the new tank so it backing up the fuel filter or my fuel pump on its way out? Because when I hit the gas,it shut down ? Need help!!!
Old Mar 11, 2015 | 12:39 PM
rossv1's Avatar
Welcome, this is probably better suited for the CL Discussion area:
Second Generation CL Discussion - AcuraZine Community (<-- click)
Old Mar 11, 2015 | 12:56 PM
Mr. Maker's Avatar
Restart it.
Old Mar 11, 2015 | 11:29 PM
mike88se's Avatar
Have you checked the fuel pressure? I'm pretty sure there is a port on one of the fuel injector rails specifically for this. You can check static pressure (key on, engine off) and if that's ok move on to residual and running tests.
I don't really understand the part in red.
Old Mar 11, 2015 | 11:36 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
Well if u replaced the gas tank and now all of a sudden you have a problem Id say you have a fuel issue of some sort for sure.
Why did you replace the tank to begin with, was there an issue with the motor running?
If not then maybe something was overlooked.whatever you are "certain about" begin to doubt it. That is likely how you are in this pickle to begin with.
Often when you think you know you stop thinking :-) so go through the steps you took when the tank was swapped and try and delineate what may have gone wrong or have been omitted.
Anyone who has worked on cars a lot has overlooked something. And when you are positive you have not that makes it almost impossible to find, cause it'll be the last place you will look.
Old Mar 12, 2015 | 05:22 PM
Jr_saber's Avatar
9th Gear
I backed up into an ice mound and made a hole in the gas tank,I didn't check the fuel pressure yet but that's my next step..
Old Mar 12, 2015 | 08:31 PM
Holy that is just unlucky bud... Sorry to hear that. But yea I'd definitley keep thinking its gas/fuel related given your circumstances.
Old Mar 24, 2015 | 02:14 PM
Jr_saber's Avatar
9th Gear
Well guys it looks like it was the fuel pump,very low fuel pressure ,I'm putting in a new one for 95bucks and call it a day,job well done
Old Mar 24, 2015 | 02:33 PM
aznboi2424's Avatar
I wonder if you heard the fuel pump priming when you turned the key to the ON position.
Old Mar 28, 2015 | 03:46 PM
I have never heard the fuel pump in my car at any point. Beats me. And I am not deaf I swear lol
Old Mar 28, 2015 | 03:55 PM
240sx acura tech's Avatar
acura master tech
main relay, electric portion of the ignition switch . bad grounds.
Old Mar 30, 2015 | 11:57 AM
aznboi2424's Avatar
You can hear it in a quiet garage. It's a high pitched whine or hiss that lasts for like 3 seconds.
Feb 25, 2020 09:57 AM
Nitin
Sep 30, 2015 08:22 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
Tsov Tom
Sep 6, 2015 07:56 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
