01 CLS vs. UTec WRX
01 CLS vs. UTec WRX
me 01cls
mods below
him 02 wrx 5-speed
intake uppipe catless turbo back, utec tuned to 17 psi
we raced from a 50 roll, i had a full tank of gas, him 1/2 tank, we each had a passanger
on the 3 honk i pulled a fender on him, then we stayed there till 110 when i dropped out of v-tec and he pulled a fender on me and it stayed that way till 135. we raced 2 times and the same thing happened. i thought it was a pretty good race. it was funny cause he thought he was gonna walk all over me.
mods below
him 02 wrx 5-speed
Originally Posted by RR32CLS
17psi tuned awd wrx VS. auto fwd cl-s
and it was fender distance
kinda hard to believe
ok, but 17psi of boost against a n/a cl-s ? rolling start or not....
Well, how much boost does it run stock? It only makes 227hp and 217 lb/ft of torque and it's all wheel drive.
he should put down right around 230 to the wheels. i should do 235-245, depending on temp and such. he is lighter also. if he didn't have such a good tune i would have beat him. the wrx runs 14.2 psi stock. the most you want to run is 16psi because anything over it is out of it's efficency range on the stock turbo. i used to own one with same mods except for utec. and have raced several, this was a good running wrx. did i mention it had altezzas?
Originally Posted by AmooManiaK
Ok, umm, what does "AWD" have to do with a rolling start? I'd rather have a RWD car from a roll than an STI, if there's no twisties of course. I heard the AWD cars actaully LOSE power on the higher end because of that. Plus, he didn't say it was an STI, so I guess it's the 227hp Impreza, or something like that.
Originally Posted by Got Rice?
AWD has a disadvantage from a roll because of the drivetrain loss. It helps out the most from a stop.
And... if you're saying 17 psi vs. NA CL... think about 2.0L vs 3.2L for a second. And I mean, one _nicely_ tuned engine from the factory. Plus mods.
Great kill bro, rep points for the technically knowledgeable.
i dont think you can run 17 psi on the stock turbo for the WRX. My brother has a 02 WRX and i think max you can go without switching to a bigger turbo is 15 psi, my brother sucks from a roll 3rd and 4th are usless in his car, race the WRX from a stop then you see what they are supposed to do.
you can do up to 18psi before fuel cut with a Utec. and with a FDC(fuel cut defender from HKS) you can run what ever you want. its just not efficent on the stock turbo. and for all you people who say awd sucks from a roll, try fwd automatics. i actually think we have the same or more drivetrain loss than an awd. yes hard to beleive but its true. wheel horse power is wheel horsepower . front rear or awd its all the same. trust me, i know more than most about WRX's
Originally Posted by Brady6226
i would also like to add that a wrx with these mods is not slow from a roll. if you dont beleive me, go race one. you can run 12's on stock wrx turbos.
Yeah, they're not SLOW, but you can see their full potential better from a stop than a rolling start.
www.car-stats.com
Car-Stats.com Report for 2002 Subaru Impreza WRX
Obtained from C&D October, 2001
0-60: 5.4 Transmission: Manual
1/4 Mile: 14.1
1/4 Speed: 96
1/4 Mile: 14.1
1/4 Speed: 96
Originally Posted by rezurex
12's stock wrx turbos?
my friend's '02 WRX with a few mods ran a 13.7
nothing near the "12's" you so claim... where did u get that info
And there is only 1 turbo...not "turbos" like you posted.
The WRXs is a little bit worse...23-25% Vs the CLs ~20% (if you're auto).
with those mods he should be trapping around 99-102mph. and btw the guy who my brother bought his exhaust from (both have 02 wrx's) ran 11.7x with a up-pipe/dp/e/UR crank pulley/stage 3 clutch/75shot on a stock turbo.
heres a race i posted a while back between my brother and his friend's stock cls. (he was running stock psi, ~14.)
http://acura-cl.com/forums/showthrea...&highlight=wrx
note: the mods we planned on buying buying fell through, the kid sold his car as is(all the parts he was selling to us).
Originally Posted by ghost_masterCL
can our CL's handle that much boost on a stock engine? 15 PSI iw WAYYY to fucking much....
http://forums.nasioc.com/forums/show...tock+turbo+wrx
My friend with up/dp/turboback/intake/pulley/16psi/lighter rims/grounding kit/chimney heat shield/sti scoop is having problems getting into high 12s. Nitrous is NOT going to put him anywhere in the 11s. Who ever told you 11s is full of shit.
**All the while being CATLESS and wrapped in heat wrap**
Originally Posted by Seattle Cl-S
Our engines were never intended to handle any boost. If Honda wanted to make a boosted engine, I pretty sure they could get one to handle 15 psi.
Still hasn't blown to my knowledge, and its been a while now.
Its the CL tranny that has major issues.
Neijb, or whatever his name is, runs 14psi on his 2.3 CL.
Its the CL tranny that has major issues.its the auto tranny that has issues... FYI neidjb's has 5 speed.
how would he not be close to 11's if hes pushing 320+ awhp? hes the owner of Import Hookup in baltimore, md (his hobby/off-time job, full time job is a loan officer, hes in his late 20's). i dont think he has anything to prove by lying. he was also running hks ems (f-con i think it is) and made the run on drag radials. before nitrous he was running mid-high 12's. he ran the 11.7 back in oct i think, its been a while since we've seen him last... no reason for me to lie either about a guy i hardly know.
Mid to high 12s is possible without nitrous...Maybe. But a 75 shot is NOT going to drop a second off to the 11s. Its not like you're dropping a second from 16s to 15s. When you get to the 12s and lower, its alot harder.
i could see a wrx dropping a second with a 75 shot, if they had good tranny's. you however would have to spray right out of the hole, and acheive a 1.6 or 1.5 60 ft time. this is also depending on weather and track condidtions. at 90degrees it woudl never happen. but say 50 degrees, you may have a chance.
oh and yes, drag radials on a awd are not needed. 8 second awd cars still use street tires. you do want some spin when doing an effictive awd launch, otherwise: shit breaks!
but the truth, wrx have worse tranny's than auto CLS'. know as the GLASS TRANNY. they were built with an imput shaft that is too long, causing them to naturally break. no matter what style the car is driven(hard or easy) they can break. subaru found a loop hole in this defect because so many people who bought the car did it for two reasons. going fast and and driving hard. i know not everyone did but most. so subaru could void the drivetrain warranty on modded cars because the drivetrain wasn't built to handle more power. saying that the modifaction gave the car more power and the tranny could not handle this. they could also void or partially pay for stock cars saying it was from abuse. now that i have actual documents saying the input shaft is too long on the cars.(which is documented from Subaru(insiders info)) i have hired a lawer to perform a class act law suit. hopefully i can get my money back.
I heard of a 12.0 with a 75 shot and exhaust...but he had the dog-gear tranny. But no way with stock gears/tranny.
my brother said the guy also has; flywheel/tmic/sti injectors/and header. oh and btw he did blow his tranny, he was getting a different trans (dont know which one) and hks turbo kit (hes an authorized hks dealer & can get it cheap). he is a member on nasioc but rarely posts ill see if my brother can find out if you have any questions for him. drag radials i meant street radials i guess whatever the hell theyre called, he had bf goodrich g-force t/a (same as me)
my oldest brothers friend has a (ive mentioned it alot on here, basically because its the fastest car ive ever been in) fully built 2.5L apu '02 wrx running 22-23 psi on a fp green 20g. on race gas he can run up to 30-35 psi and hes doing it all thorugh his stock trans, hes been waiting for it to blow for a while, which it has yet to do.
