01 CLS flasher replacment for LED Bulbs?
Old Mar 18, 2011 | 04:48 PM
Kendreth's Avatar
Maj Incident ResponseTeam
Exclamation 01 CLS flasher replacment for LED Bulbs?
I want to change all of my bulbs to LED's. i have the part numbers for replacment of 1157a, 7440, and 7443. what i need to know is if there is the "hyperflash" problem. i would rather replace the flasher units than put in the load resistors.
www.superbrightleds.com sells replacment flasher units that replace oem and work with the LED bulbs, but what is the factory flasher pin configuration?
here is the list from that site http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/flashers.htm
are any of these correct? do i even need to deal with this? if i just plug in the damn bulbs will everything be fine ?
just want to know before i order the bulbs, want to get everything at once. Thanks !!
Old Mar 18, 2011 | 08:47 PM
StreetKA's Avatar
i want to put switch back in the headlights im interested as well
Old Mar 23, 2011 | 04:25 PM
Kendreth's Avatar
headlight flasher?
? you want a flasher for your headlights? if there not HID (like mabey your highbeams) you can get a universal flasher unit from galls (also known as wig-wags), but unless you have a reason to have them you cant use them on the road its illegal. something about impersonating law enforcment blablabla... cops always keep the cool stuff for themselves.
Old Mar 26, 2011 | 10:22 AM
ceagles1000's Avatar
You will have a hyper flash problem. Just buy the unit I think its called a relay. You plug it under the dash on the drivers side. I had to take a knife and cut off some plastic for it to fit. When I bought the one for our car it was a lot fatter and didnt fit. I was real disappointed - it was the correct one though. It was easy to make it fit though.
Also I wouldnt buy the switch backs. I did. They look great however I paid $70 for them and one blew out in like a month and the other in 3 months. These companies will not give you a warranty.
Old Mar 26, 2011 | 12:25 PM
ghttf's Avatar
you need this one
http://www.superbrightleds.com/cgi-b...CF13JL-02.html
remove the plastic to make it fit
Old Mar 26, 2011 | 03:21 PM
Kendreth's Avatar
thanks guys
Old Mar 26, 2011 | 04:30 PM
1foxbody's Avatar
03 CLS-6
Can you do a list of all the bulbs for our car? I want to place a order with them also.
Old Mar 30, 2011 | 01:56 AM
dave586270's Avatar
Chamorro
The switchbacks are where its at! I've had mine for a while and people are always staring!
Old Apr 1, 2011 | 02:38 PM
Kendreth's Avatar
what do you mean by "switchbacks" i dont get it?
Old Apr 1, 2011 | 04:15 PM
1foxbody's Avatar
03 CLS-6
That looks so illegal and asking to get pulled over haha.
Old Apr 1, 2011 | 06:23 PM
Kendreth's Avatar
SWITCHBACKS? WTF are they!
im gonna go with the "tower" style SMD Led they are more money but you get a brighter bulb im trying to see if the 45led units will fit in the tail lights, the 18led ones will though.
WILL SOMEONE PLEASE EXPLAIN SWITCHBACKS TO ME!!!!!
im putting in a full hide-away strobe system in my car (im a EMT, and have a strobe light problem... its better than crack though, right? ) but what is a switchback???????
Old Apr 1, 2011 | 06:42 PM
StreetKA's Avatar
http://www.youtube.com/watch?v=KmUsiKqIC5Q
Old Apr 1, 2011 | 06:44 PM
civicdrivr's Avatar
Switchbacks - LED lights that blink amber when the blinker is engaged but illuminate white/blue when static.
Old Apr 1, 2011 | 09:16 PM
dave586270's Avatar
Chamorro
I just means that there are two different LED's that switch back and forth when the blinker is turned on.
Not at all. They just have be amber when the signal is turned on!
Much better vid than mine!
Exactly...
Old Apr 2, 2011 | 02:58 PM
ghttf's Avatar
Audis have switchbacks from the factory.
http://www.youtube.com/watch?v=rC9SZSvlpMA
Old Apr 8, 2011 | 06:18 PM
Kendreth's Avatar
cool looks real clean. where can you get them bulbs or is it a diffrent socket setup? someone said that they burn up real quick.
oo7spy
Jun 19, 2023 12:48 AM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
Mcj270
Aug 31, 2015 04:45 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
