*i Need Help*
*i Need Help*
i'm installing my stereo right now. my battery was disconnected and now i need to enter my code to get the deck to turn on again. only problem is my manual w/ the number is 300 miles away
will any code do, or are they deck specific?
any ideas???
you can pm me a code or
any ideas???
to my knowledge, they are deck specific. Is there someone that has access to the code, I would suggest calling him/her and get the code. I'm sure if you call Acura, they would have it accessible somewhere, it just might be a pain in the ass. Good Luck.
I had this problem....I even had the wrong code! I had to take off the bowling ball trim and on the right side of the rasio there is a number--( serial number) on a white sticker....Call any acura service dept. and give them that #...They will give you your unique code....You can also give them your vin number and they can provide you with the code, but in my case the radio had been swapped out and I never got the correct code...
Good luck
Good luck
Originally posted by pofi
that is kind of sketchy that you can just give the dealer your VIN, since that can be easily obtained from the dash... from outside the car!!!!!
Originally posted by Crazy Sellout
cant you call someone that is near your manual?
long story short, the guy who likely has my book is a guy from portland that works at PIAA. so i gotta call alta sport (local shop) tomorrow to get his number.
i don't think the 10 oz. weight savings was worth it :o
Originally posted by darrinb
Damn u really do strip your car a lot, do you not eat and make your self throw up the week before you go the track to?? j/k
Just make sure that stereo dont add weight to ur car!!
I had the exact same problem while hardwiring my Passport. All I did was call my dealership, talked to my salesperson
(who remembered me thankfully). He got me in touch with their service department and they gave me my code in 2 minutes. Hope this helps you.
From the owners manual..."you have 10 attempts to unlock....after 10 invalid entries, you ust leave the car running for 1/2 hour before trying again--" or you can just unplug the battery! Best bet is to take off the center trim ( right side) and get that number off of the side of the radio--then call/visit the dealer--They will look it up
I did this last week...And yes, they gave it to me over the phone after they looked up my work # in their records
most thieves will take whole cars to places called chop shops where the vehicle is worth more in parts than as a whole. that entails removing the stereo which then entails using the access code to make it functional again otherwise rendering the stereo useless. what? is jersey the only place with chop shops?
i can save 1.3562 pounds that way.
