$400 for a 30k checkup...
Old Feb 3, 2003 | 02:56 PM
WebToker's Avatar
Is $400 the going rate for 30k checkups? I just called two dealerships and go that estimate.
Old Feb 3, 2003 | 03:13 PM
Caddyİ's Avatar
Sounds about right, Its about 422 Here in Chattanooga, TN !
OutRageous
Old Feb 3, 2003 | 03:21 PM
dbox's Avatar
whoXwanXsum
yep yep. if your not going to keep the car dont take it to the dealer, you can get it done alot less.
Old Feb 3, 2003 | 03:28 PM
mantis23's Avatar
Moderator Alumnus
uhh no, I paid 150 something...
I had the dealer and take out the stuff I didn't need, or the stuff they wanted to much for (the air filter replacement charge was outrageous).
If you need everything on the list, then yeah its gonna cost that much, but I'm sure you can get them to knock off a couple hundred bucks.
Old Feb 3, 2003 | 07:56 PM
JSuppi's Avatar
Damn...
Damn dude you suck!!!! You're just hitting 30k now??? I have doubled that and then some
Old Feb 3, 2003 | 08:13 PM
sorty's Avatar
Peace. I'm out.
469 for my 15k service...u thought 30k was bad?
Old Feb 3, 2003 | 09:11 PM
russianDude's Avatar
Two big items you can save money on 30K maintance, tell you dealer to skip the following:
- Coolant flush (can wait till 45K according to manual) $50
- Brake fluid ($40-50?) can wait till 45K mile
Also, I would do air-filter replacement myself ( save like $20 ).
So you can save like 100, which still make your bill like $300.
I think $300 is worth it, I skiped all the check ups, and will only do major ones at 30, 60, 90 ....
Old Feb 3, 2003 | 11:11 PM
Nicky Pass's Avatar
Fuct in the hed!
Do what Mantis did...don't have them do anything you don't need...I think there is a check list for the 30K
Old Feb 3, 2003 | 11:30 PM
soopa's Avatar
The Creator
im just bout ready for 30k... what are they supposed to do?
im sure most of it is unneccesary.
i wont pay more then $100. heh
Old Feb 3, 2003 | 11:33 PM
soopa's Avatar
The Creator
Services to be performed:
Replace engine oil, filter and drain plug washer with Genuine Acura Parts.
Inspect and rotate tires.
Inspect wiper blades.
Check/adjust fluid levels.
Road test.
Replace air filter with Genuine Acura Parts.
Inspect belts, hoses, fuel lines and exhaust system.
Inspect front and rear brake assemblies.
Inspect steering system, suspension components, alignment and parking brake.
so pretty much all i need done is
can you say JIFFY LUBE! heh
Old Feb 4, 2003 | 01:22 AM
mattg's Avatar
you were raped. there is no necessary service at 15k. i do my own oil changes etc. so no use for the 30k either.
Old Feb 4, 2003 | 02:32 AM
VTECPOWER's Avatar
so guys, is it really necessary to go to dealer for 15k service or can wait until 30k?
BTW how's oakland acura service??? b/c will go there for 15k checkups.
Old Feb 4, 2003 | 07:07 AM
Loseit's Avatar
Changin bulbs since '73
i'm about due fot 30 K service as well!! I don't think i need all the supspension stuff since they just worked on mine or even tires/ balancing etc. hopefully that'll save some cash.
Old Feb 4, 2003 | 08:39 AM
CO-CL-S's Avatar
I paid $141.00 for 30K. But I'm sure somebody will advise "You get what you pay for.". I say, bend over cause you're being "*&@$(*@&".. YMMV
InFaMouSLink
Oct 30, 2015 09:43 AM
Thuneau
Oct 3, 2015 04:19 PM
hashbrown
Sep 29, 2015 12:13 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
Hines57
Sep 24, 2015 01:58 PM
