Will these fit?
Will these fit?
I just got my 06 TSX today, Hurrah. Got some leftover rims from my old car. Let me know if you guys think it can fit (I'm too lazy and busy to do trial and error)
19" Work Euroline XR
width: 9 front / 10 rear
+35 Hi-Disk offset
+35 Hi-Disk offset
apparently you ARE very lazy, you didnt even check if you posted in the right place
ttk5 (11-13-2011)
Bolt pattern is 5x114.3, I know its the same for Acura as well. I'm just coming from a G35 coupe, where I know pretty much anything and everything fits, back to my honda/acura roots.
I'm just wondering if they will fit without rubbing issues. I know it'll look like a monster truck so I'm going to end up dropping it to a 2 finger gap space in the future.
Welcome to the forums. Thread moved to 1G TSX.
Thanks for the welcome I wasn't trying to be a dick, but come on, it was an honest mistake. I was on the site for 5 minutes and I should've read more carefully.
Bulleh (11-13-2011)
A couple of concerns would be the hub size and the offset. The hub size is the major concern. If you were using using hub rings with the Infiniti, then you may be able to get the right size rings for the TSX. Otherwise, I'm sure that the hub size of the Infinti is different than that of the TSX so it's a no go. Also, the offset is pretty radical. The OE wheels are et55, so you've got 20MM less offset with your wheels (they'll stick out that much more). Add the increase in width, and you're looking at a major rice mobile (if you know what I mean). That said, I can't help but add that I'm squarely in the "staggered wheels look stupid on a FWD car", but to each their own.
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
