tires rubbing in front
my tsx is lowered and i have 18/ 7.5 inch wheels with 42 offset. i experience some fender rubbing at times when pulling into driveways. should i increase the camber or just raise the suspension?
i have a similar problem on my 17x8 +42 rims lowered about 2" (225/45 tires)
I recently ordered an eibach front camber kit to help remedy the problem
if you're running a 235 wide tyre that may be contributing aswell.
like someone else sugested, tuck in your fender lining behind the fender and you should have the few mm you need to stop the rubbing.
take a look at this..this was done by pro but I know few people rolled their fender with baseball bat...pretty stupid but yeah..
http://www.mazda6tech.com/index.php?...id=17&Itemid=1
i have 235 tire, what do you mean by tucking the liner inside? I guess i'll have to look and figure out what you are talking about...
inside the wheel well there is a plastic lining held in by plastic clips... if you take the clips out you'll be able push the plastic lining up in behind the actual fender giving you a few extra mm of clearance
I'm trying extra negative camber so i can go a bit lower...
does anyone know how to calculate how much the edge of the wheel will tilt in (in millimetres per degree of negative camber?)
Originally Posted by S14 n Tsx
^^ you bascially rolling the fender line. I really dont recommend that at all. You can actually damage your paint or the fender.
we just tucked the fender lining....(take the clips off anf move the fender liner inside) It's very simply and will minimize rubbing.
Originally Posted by llJrockll
Xizor and I are not talking about 'rolling fenders'......
I just ordered a set of wheels in 18 x 7.5 with a +45 offset, and this thread has got me worried that I'll rub since I'm dropped ~2 in (and possibly a little more in the future). Based on my rough measurements, I should have about 0.1 in (or ~3mm) worth of clearance if I go with 225/40 tires and I'm wondering if that's cutting it too close.
Originally Posted by DAYTA
So are there any adverse effects to tucking the fender lining? Also, do you move the entire lining, or just the top part?
You should be fine with your size and offset. I doub't you'll rub if you're only 2" inch dropped with 225 or 235 series tires. The only adverse efects you'll have by tuckin the fender lining is you will have more clearence, believe me I was rubbing on sharp turns and dips. If you do 'tuck in'....You should remove all the clips at the top, just to let you know if you tuck in the top, you might have to tuck in lining all the way around.
Could I potentially just cut off the portion of the lining that rubs or would it be better to just tuck it?
How is having more clearance considered adverse? Or were you just being facetious ?
I guess I meant to be humorous……it's kinda hard to notice in writing. I'm such a fool. Anyway…..obviously you will have more clearance by tuckin' in the fender.
I wouldn't suggest cutting off the lining, why would you want to do that when you can just save yourself the time and 'tuck in'. it's really fast and easy not time consuming whatsoever. And after that if you raise your car you can 'untuck' the fender and then clip the tabs back on. (If you do end up doing this, I suggest you save and hold on to the clips/tabs.)
Do you guys think I would have any rubbing problems running a set of 18x7.5 +50 w/ 235/40 tires and a 3 inch drop?
I DONT want to tuck in the fender lining and plus I like to corner hard, would it be safer to go with 225 series?
You should be fine. Xizor ( a member here) was dropped pretty low, lower than 3" with 18x8 +45 w/225/40 tires....
Originally Posted by xizor
I compared my height to a new stock 2006 today
Front 3 5/16" and the rear 3 1/16" drop.
https://acurazine.com/forums/showthread.php?t=31063
the rubbing happens more when you pull into a steep entrance and the wheels are turned at more of an angle. my back wheels dont rub and the rear is actually lowered more on my tsx.
So, what wheels are YOU getting ??
I was also debating between 225 and 235 tires, but I plan on going with 225s for the better performance aspect (along with the smaller potential of rubbing). Why were you planning to go with 235s?
if you don't want to rub, I'd suggest getting 225's
I had a set of 17x8 +45 235/45/17 and rubbed a bit, went to 18x8 +45 225/40/18 and never ever rubbed
hmmm, now I dont know what to do. Im looking to basically have no gap maybe even tuck a little bit of tire. You definetly think I would have problems with the 235 series?
TLDude876
12-28-2016 03:18 PM
nuldabz
09-03-2015 05:49 PM
